Pop going out of 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Jan 2, 2013.
  1. Jan 2, 2013 at 7:20 AM
    Mr.Gadget
    Mr.Gadget [OP] Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Guys is it normal to have a pop, and binding feel coming out of 4x4.
    Don't remember it on the 2011 but the 2012 has more feel like the front end is binding up.
    It happens moving or when you start moving after switching out af 4x4.
    I have been using the 4x4 a little more hunting in the past months to move the ATV trailer, backing in the yard, on the side of the road.....
    I tried several times to make sure the tires are not turning much if any left or right.
    Going to check the tire pressure tonight but they look fine, I checked them when I aired up for towing.
    It does not feel like ti is front to back but like my old dodge would do if you had the wheel turned a good bit then shift in and out.
    Not too sure about the 4x4 system I thing these trucks have a disconect on the front axle, and then it shifts the transfer case also, that correct?
    IF so it soulds likt the disconnect is binding and when it lets loose it pops good. As the sound and feel is from the front diff area.
    The truck has not been used hard or run off road, no playing in the mud...
    So the front gear should be fine, I have had broken teeth on a ring in the past of my off road rig, so I know it is not that, not near as bad, but close to the same feel.
    Any thoughts.
    My only though is that its normal, just loading up one tire more due to the ground or path, but just a little loud, never a problem running in 4x4 or 2WD..
  2. Jan 2, 2013 at 7:24 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    4x4 pops when moving. Make sure that you're stopped or in neutral if moving when you switch the 4x4 on and off. Well that's what I do anyway.
  3. Jan 2, 2013 at 7:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's normal. If you take your foot off the accelerator when switching to 2hi, it will lessen the chance of it popping.
  4. Jan 2, 2013 at 7:28 AM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    Also make sure the wheels are pointed straight forward.
  5. Jan 2, 2013 at 7:28 AM
    ToyotaKTMracing
    Shay
    West Virginia
    This too
  6. Jan 2, 2013 at 7:38 AM
    Mr.Gadget
    NC
    10-4 have been doing that.
    I think it is something like the AC running and adding pressure when you are just rolling.. I will kick it in netural next time.
    I feel the AC or what ever it is that kicks up the RPM's from time to time.
    Being at a light, stop, then you feel like the truck is tring to take off or bumped the gas....
    Maybe it is tied to that as most all the time I just started the truck to move the trailer.
  7. Jan 4, 2013 at 8:24 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    My 13' does this in and out of 4WD. Not every time but enough...
  8. Jan 4, 2013 at 10:21 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    If mine pops that means I didn't take the load off of the system before shifting it out. Usually just a very gentle deceleration while going back into 2wd is enough to make it near silent. Same when going into 4WD, it shifts in much more reliably with just enough throttle to imitating freewheeling.
    It's the same principle as shifting a stick shift into neutral without pushing the clutch. If you don't feather the throttle, it's gonna pop out hard.
