Pop & Lock PL8521 install with new bracket
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaTruckParts, Oct 13, 2014.
  1. Oct 13, 2014 at 10:41 PM
    TacomaTruckParts
    TacomaTruckParts [OP] Well-Known Member
    Jesse
    San Gabriel
    UPDATE: The brackets are now fully laser-cut and powdercoated black and still the same price + FREE S&H - $17.00.
    Howdy,
    I recently bought and installed the Pop & Lock PL8521 Power Tailgate Lock for my 2012 DCLB 4x4..... I liked it, but the mounting design seemed like it could be improved upon. I ended up designing the bracket you see in the pictures below. I also added two foam blocks to keep the power lock in place and to minimize noise and vibration.
    I am offering these reinforcement brackets for the 2005 - 2015 Toyota Tacoma. They are available. $17.00 includes free S&H. to the lower 48 states. These are fully CNC-laser cut & formed, powder coated black. You can purchase with pay pal at TacomaTruckParts.com *I painted the one in the pictures "Caterpillar Yellow" for clarity.
    Designed to fit all PL8521 power tailgate locks on all Toyota Tacoma models 2005 - 2015, with and w/o the back-up camera.
    Let me know what you all think....
    Jesse
    You can see the two screws on the PL8521 which we will attach the new bracket with. Do not remove both screws at the same time. Attach the bracket with one screw first, only tighten after both screws are attaching the new bracket.
    Remove both outer 10mm bolts. These will be re-used. You should not need any thread locking compound; If you do use any, a low strength is recommended.
    You can see that with-out the reinforcement bracket, the PL8521 is attached with a single bolt. Not the best design.
    A much better design and a more solidly mounted power tailgate lock. The TacomaTruckParts bracket does not interfere with the back-up camera or the tailgate latch mechanism.
    I bundled the PL8521 wires into the plastic sleeve that the back-up camera wires are in, so that I had only one wire bundle going from the tailgate to the body.... for a cleaner look.
    The black PL8521 power connector right above the white back-up camera connector plug.
    Run the wires along the top of the passenger side frame rail. Make sure to zip-tie through frame holes every 6" or so. This is where the PL8521 wires enter the cab on a 2012 DCLB SR5 4x4 - under the front passenger seat.
    Right under the forward end of the front passenger seat is where this rubber body plug is. Perfect location to enter the cab and easy to seal with RTV.
    Running along the door wire-harness frame to the front passenger foot well / kick panel. Remove the plastic sill, starting at the back end, by pulling straight up.
    Remove the kick panel by first removing the black plastic nut with the three holes in it - just unscrew it by hand. Then pull the panel rearward with a quick tug. You can see the wire bundle you need to tap into. I coiled up the extra length of wire.
    Now back to the tailgate. Using a 10mm. wrench, remove the two bolts attaching the PL8521/bracket.
    Flip the PL8521 over and attach a piece of foam (about 25mm thick) with double-stick tape to the metal bracket, under the plastic solenoid housing.
    Flip the PL8521 back over and re-attach the two 10mm bolts, make sure to properly torque the bolts. Now attach another piece of foam (about 29mm thick) with double-stick tape to the plastic solenoid housing. Align it so that the top foam is directly over the bottom foam.
    Norton, TRDSport10 and Bobcdn like this.
  2. Oct 13, 2014 at 11:11 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Nice piece. Looks clean.
    Can you do a metal sleeve to slide over the plastic rod thing on the handle? The piece that pushes on the metal wing to activate the latch. I have a feeling that will wear out over time and create too much play when locked.
  3. Oct 14, 2014 at 11:59 AM
    TacomaTruckParts
    Jesse
    San Gabriel
    I have had my 2005 Tacoma PreRunner since new and have not had any issues with wear on that part. I do understand your concern, I just dont think that wear is going to be a problem..... Thanks for pointing that out.
    It may be something I investigate further.
    Jesse
  4. Oct 22, 2014 at 7:49 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Do you have any in stock now? I'll order tonight if yes.
  5. Oct 22, 2014 at 9:12 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    I sure do have some.....
  6. Oct 23, 2014 at 5:46 AM
    TRD2013Chris
    TRD2013Chris Well-Known Member
    chris
    CT
    Black 2013 Tacoma TRD Sport Dbl Cab Long bed
    I have had mine for over a year now, works great, had to mess with the spring once b.c it came unhooked. but i love it. I can go into a store knowing my tools will be safe!
  7. Oct 24, 2014 at 2:33 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Yeah, that springs seems like the weak point in their design.
    Jesse
  8. Oct 24, 2014 at 2:57 PM
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    So I assume these need to be painted to resist rust and corrosion?
  9. Oct 24, 2014 at 4:42 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Yes, they are made from cold rolled steel, which will rust if not treated properly.
    I was going to have them powder coated, but decided to reduce the cost, and let the buyer prime and paint them. I might get the next batch powder coated, zinc plated, or maybe go with stainless steel.
  10. Oct 29, 2014 at 9:59 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Still have a few left...
    Jesse
  11. Oct 30, 2014 at 11:08 AM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    I am interested in purchasing one. I sent you an email from your website.
  12. Oct 30, 2014 at 12:10 PM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    $17 seems like a lot until you consider the hassle of making one for yourself. I'd do it right now except I don't do PayPal. Other payment options?
  13. Nov 5, 2014 at 1:24 PM
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    Your part is well designed, shipped promptly and installed easily. It does exactly what you advertised. Per the Subject: "Thank you"!
  14. Nov 5, 2014 at 4:27 PM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    I received mine the other day. It is strong and as TacoLarry said "well designed". I will be painting it and installing it this weekend. Thanks Jesse.
  15. Nov 15, 2014 at 7:27 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    placed my order...but after it re-directed me an error page came up. can you confirm the order went through without any trouble please?
    Ricardo Santos is my name.
    edit: got a confirmation email...should be good.
  16. Nov 15, 2014 at 10:10 AM
    seatrout
    seatrout Member
    west coast, BC, Canada
    2014 TRD DCLB
    Hi,
    Will you ship it to Canada? How much extra, If so?
    Thanks!
  17. Nov 15, 2014 at 5:57 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Thank you for your purchase.
    I did get your order, and I mailed it today. You should get it by the middle of next week -- Thanks for the support.
    I will ship to Canada..... just add $2.00 extra to cover the extra postage cost. PM or email me ( jesse@tacomatruckparts.com ) if you have any questions.
    Jesse
  18. Nov 15, 2014 at 6:24 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Still have any in stock? I not got my pop and lock in the mail but have not installed it yet. I was gonna try to do something like this myself but this looks killer.
  19. Nov 15, 2014 at 10:01 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Yes, I still have a few left.
    I usually ship same day, so you would not have to wait long to get the power lock installed in your truck.
    Jesse
  20. Dec 12, 2014 at 12:26 AM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3 Demello front bumper Brute force rear bumper
    Anymore in stock?
