Pop N Lock w/Backup Cam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solo707, Aug 19, 2013.
  1. Aug 19, 2013 at 11:26 PM
    Solo707
    Solo707 [OP] Well-Known Member
    NorCal
    2013 TRD Off-Road
    Plasti-Dipped Badges
    From what I understand the pop n lock installation requires the backup cam to be switched from the passenger side to the drivers side of the latch. I like to park into spots backwards using the lines on the rear view mirror. Does the relocation of the cam affect the way the display looks in the rear view mirror?
  2. Aug 20, 2013 at 12:08 AM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    If you get the power pop lock you don't gotta worry about swapping nothing. It just taps into your door lock wiring and lock/unlock with your remote. Convenient product in my book. Less visual deterrence but very convenient. Not too hard an install either. Just my $.02
  3. Aug 20, 2013 at 12:20 AM
    Solo707
    NorCal
    2013 TRD Off-Road
    Are you saying the power pop n lock doesn't change the camera location?
  4. Aug 20, 2013 at 12:28 AM
    hirod
    hawaii
    Camera stays the same. No exterior modifications. There's a plate that has the actuator which mounts to the inside of the tailgate. Try look up the installation instructions. If I recall they're online cause they don't come in the packaging. No conspicuous silver lock on the tailgate though. A good and bad thing I guess
  5. Aug 20, 2013 at 12:39 AM
    linuxtwit
    linuxtwit Member
    Picture Butte, Alberta
    16 DC/LB TRD Sport Upgrade Pkg. Cdn. Version
    As far as I can tell, the relocation of the camera doesn't affect the display. My display looks the same as before I installed the pop n lock 5300, and I also use the guidelines to back into parking spaces.
  6. Aug 20, 2013 at 1:09 AM
    Solo707
    NorCal
    2013 TRD Off-Road
  7. Aug 20, 2013 at 3:29 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Did you try this?
    http://www.popandlock.net/index.php?route=information/locator
  8. Aug 20, 2013 at 4:23 AM
    peiscooter
    peiscooter Currently on a Tacoma vacation
    Prince Edward Island
    Ex - '12 DCab TRD Sport, Currently '16 RAM Laramie 5.7 Hemi
    Same here!
  9. Aug 20, 2013 at 6:15 AM
    faststang90
    faststang90 Well-Known Member
    dwayne
    houston
    2010 Pre Runner
    yes it moves it to the other side. i dont know what it looked like on the other side so i cant tell you it was better on the other side.
  10. Aug 20, 2013 at 7:51 AM
    sdsyver
    sdsyver Well-Known Member
    Did mine the other day and found that it off centre now about 4-6" or the width that it moved. Everything still functions but is out a bit. Kind of annoys me actually.
  11. Aug 20, 2013 at 8:02 AM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Fort Nelson, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    My back up cam was already off centre. After installing the Pop N Lock it is still off centre, but now in the other direction. Not a big deal as it is only by 2-3 inches.
  12. Aug 20, 2013 at 8:54 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    This is the picture of the pop lock that I got. I found that the angle of the camera is changed a little bit. I found that it's facing down a bit more. I can see my license plate lights more. Either way, it hasn't effected me seeing through the camera etc.
