Pop sound from the tailpipe?
Discussion in '4 Cylinder' started by 4X4SUPERWHITE, May 13, 2012.
  1. May 13, 2012 at 9:36 AM
    4X4SUPERWHITE
    4X4SUPERWHITE [OP] Active Member
    MA
    Stock,V6 SR5 DC
    stock
    I have a 2011 with a 2.7L, with less 10k., when I first start it in the morning I can hear a soft pop sound from the tailpipe:(. It doesn't do this very first time in the morning. Is this a common thing or should I be worry? :confused:Has anybody had this problem?
  2. May 13, 2012 at 9:37 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    happens all the time, nothing to worry about :) just another one of those 4 banger things we live with
  3. May 13, 2012 at 9:43 AM
    4X4SUPERWHITE
    MA
    Stock,V6 SR5 DC
    stock
    Ok,thanks. I just don't want it, to get any worse down the road.
  4. May 14, 2012 at 7:01 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    When I first got my truck, as I started it up to back out of the garage, my wife would say "it sounds like your truck is backfiring"...
    Its normal, and I believe it has something to do with emissions... something about trapped gases in the converter or something like that as I remember...
  5. May 14, 2012 at 7:10 AM
    joes06tacoma
    Joe
    Central Coast, CA
    We have two identical 2009 2.7's at work. Both do it. One has around 40K on it, the other 60K. No problems with either one of them.
