Poplock (PL5300) 2009 Tacoma with Cam -Install Tutorial
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma-09, Oct 23, 2009.
  1. Oct 23, 2009 at 11:49 AM
    Tacoma-09
    Tacoma-09 [OP] Well-Known Member
    Ft Lauderdale, Florida
    09 Taco TRD Sport DC
    Hi all,
    After waiting many many months for Pop & Lock to develop and release the PL5300 for my 2009 Tacoma with backup Cam It finally arrived at my front door thanks to the group buy here at Tacomaworld.
    Tools Needed for installation.
    1. Small flat screwdriver
    2. Box cutter
    3. 10 mm Socket set
    Time take to install
    Took me around 30 mins - Considering that I was taking pictures and really just taking my time this really should not take longer than 15 to 20 mins to install. There are one or two tricky steps but honestly this is a basic install.
    Here is the PL5300 still in the packaging.
    Even though it is late October sunny weather in Florida time to get cracking with the installation
    The instructions for the PL5300 come inside the package, although I found them useful there was two things they never told me.
    1: How to detach the camera from it's harness and
    2: A easy way of rerouting the cable (I will explain later on it is fairly straight forward.) This has to be done as the cam is now on the left hand side of the pop lock the factory fitted opener has the cam on the right hand side.
    First things first - lower your tailgate and remove the 15 screws highlightd in the following picture.
    There are two sizes of screws to remove from the tail gate
    These are the large ones (at the top of the tail gate)
    I did not have the special type of screw driver to remove them so I used a flat screw driver of the same diameter and was able to unscrew them no problem.
    These are the small ones. In total remove 15 of them
    Once you get all the screws undone simply pop off the tail gate lining. The top stays on as pictured here
    This is what the factory fit looks like. See the Red and black rod holders there is a trick to removing them without snapping them I will show you in the next picture.
    The best way to remove these rod holders is as follows
    Number 3 points to a GAP in the rod holder the rod is marked 1 - slip the rod out of the GAP marked three. Once you have the rod out of the rod holder, leave the rod holders in place. You will be able to remove them once you have the factory handle removed by simply squeezing them from the bottom. If you try to force them out while the handle is still installed you will break them.
    Here is a close up of the rod holder once I had mine removed.
    Next up is to remove the factory handle.
    Use a 10mm socket and undo both bolts. Pretty straight forward here.
    I found it was real easy to remove the cam once I had removed the factory handle off the Tacoma.
    Simply squeeze the tab pointed out here as #1 once you squeeze the tab you can unplug the cam harness quite easily.
    The next thing was to get the cam mounted into the PL5300.
    Simply undo the two small screws from the PL5300 and the blank cover comes off. Once you have done this your PL5300 will look like this.
    Fitting the cam into the PL5300
    this was a little tricky. The cam will only go into the 5300 one way! - do not try and force it any other way. There are two small screws (supplied by Pop & lock) that screw the cam into place as well as the screws there are two plastic inserts that match up with two holes once you have the two screws and the inserts matched up simply screw it down before actually fitting the cam into the PL5300
    Prior to screwing the cam in
    Once the cam has been screwed into the PL5300 Holder it will look like this
    Now you are able to fit the cam into the PL5300 it sits nice and snug into the cam hole as follows.
    Here is another view of the cam in the PL5300
    Routing the cam harness cable
    Here is a before and after shot. The cable as you can see in black is where it is run by the factory, highlighted in orange is how to run the cable in order to facilitate the cam on the other side of the handle.
    Once I re routed the cable I used insulation tape to hold it down right at #2 on the picture
    I found the best way to dislodge the cable from the holders is to use a box cutter and slice away the factory tape as shown here.
    Once I re routed the cable I used insulation tape to hold it back in place
    again.
    Pictured here is where I used insulation tape to hold the re routed cable in place (#1 and #2)
    Thats it. Once I rerouted the cable I screwed in the PL5300 using the original factory bolts and the 10mm socket.
    If all goes to plan you should be left over with the following "spare" bolts and screws.
    Any more and..... you must have left something out :)
    The last thing left to do was to test to make sure that the cam was still working.....
    Thats it. Total time for install was around 30 mins. I certainly hope that this little install tutorial helps someone.
    kcdonegan, markair, Slashaar and 3 others like this.
  2. Oct 23, 2009 at 11:56 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Excellent writeup!
  3. Oct 23, 2009 at 12:58 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Excellent write-up and photos. I love this lock! I'd recommend it to anyone.
  4. Oct 23, 2009 at 1:01 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    A+ Nice write up!
  5. Oct 23, 2009 at 1:04 PM
    kungfupanda
    kungfupanda Well-Known Member
    So Cal, Cerritos
    2010 4x2 Taco TRD SPORT
    HID - Low, LED interior lights, LED license plate light, HID Yellow fog lights, Access Limited Roll Cover, Hitch/Tow Package, Ceramic Tint, Wet Okole's, Magnaflow Exhaust, DFab Bars, Bully Bar Back, HID Yellow Fog Lights
  6. Oct 23, 2009 at 2:20 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Great write up. Do you think that you could have finished a lil faster if you had the correct Torx bit? 20 min maybe... Just giving you a hard time great write up. I am heading outside to do this now. One more thing.... for some of us that were having a hard time removing the key unless it was locked? Solution is not to file it down but rather a bit of graphite spray (used by locksmiths and such) will allow you to easily remove the key. Work great. I learned this after taking the PL5300 to the local locksmith to make extra keys. Just FYI.
  7. Oct 23, 2009 at 2:41 PM
    Tacomake
    Tacomake Member
    07 Double Cab TRD - Speedway Blue
    GATR Systems Tracking (www.gatrsystems.com) Access Limited Edition Toneau Electric Pop N Lock for Tailgate
    Do they have this model with the electric lock as well?
  8. Oct 23, 2009 at 2:51 PM
    Capita
    yup, I think its the 8520
  9. Oct 23, 2009 at 2:51 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    Very Nice this will help me out alot. Thank you.
  10. Oct 23, 2009 at 2:52 PM
    CableTec
    CableTec Legend in my own mind
    J-ville and P-ville, FL
    2007 V6 PreRunner SR5 TRD
    See sig.....
    Nice write up......without the camera mounting, this install should take no more than 10 minutes tops.
  11. Oct 23, 2009 at 3:01 PM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    good write up..installed mine the other day..pretty simple..
  12. Oct 23, 2009 at 3:36 PM
    Faskev
    Faskev Well-Known Member
    Awesome write-up! I highly recommend this product, it should have came factory!
  13. Oct 23, 2009 at 3:41 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Nice...I might have to invest in one.
  14. Oct 23, 2009 at 3:53 PM
    Beale
    Beale Member
    NB, Canada
    06 Tacoma 4x4 TRD Offroad
    Looking at the construction of the tail gate, I now understand why they fold!
  15. Oct 23, 2009 at 3:54 PM
    DellGSG5
    DellGSG5 Well-Known Member
    Dell
    San Diego, California
    2009 PreRunner TRD
    Step rail, Grill guard, bug deflector,bed lights, Window Deflectors.
    Nice write up, thanks for posting these.
  16. Oct 23, 2009 at 4:03 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Just finished installing.. The rerouting of the original cam wire is key. I also noticed that the tailgate cover has an alignment post at the top center, just be careful when removing and when replacing. I believe that Tacoma09 covered everything else very well. Great help in installing mine. Thanks Tacoma09
  17. Oct 23, 2009 at 4:10 PM
    Tacoma-09
    Glad you got your installed. Yeah I forgot to mention about the alignment post. Once you have that in place installing the cover is a breeze.
    Thanks for all the kind comments it is appreciated.
  18. Oct 23, 2009 at 4:28 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    i didnt even order the pop n lock's but wow man great write up. if/when i get mine i can definitely use this to walk me through it :thumbsup:
  19. Oct 23, 2009 at 4:46 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Excellent detail, thanks! A PL-5300 is next up for me once my ScangaugeII finishes traversing half the continent on what must be the slowest mail truck in existence.
  20. Oct 23, 2009 at 5:21 PM
    Semperfi
    Semperfi Well-Known Member
    Angel Fire, New Mexico
    2010 Off Road S/B
    Just installed mine today, good product.
