Popping / clunking after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sandtaco10851, Apr 12, 2020.
  1. Apr 17, 2020 at 4:07 PM
    #41
    Sandtaco10851
    Sandtaco10851 [OP] Well-Known Member
    SoCal
    2017 Tacoma TRD PRO
    Here’s a better video. Sounds like it’s in my diff or a slip yoke lube issue
    t0nyvalenzuela likes this.
  2. Apr 17, 2020 at 5:04 PM
    #42
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Slip joint noises usually show up when coming to a stop.
    If anything, I'd say it's rotarional slop in your u-joint...
    Have you tried greasing it yet?
  3. Apr 17, 2020 at 6:29 PM
    #43
    Sandtaco10851
    SoCal
    2017 Tacoma TRD PRO
    I have not tried greasing yet. Since there’s no zero fitting on my 2017, I would need to pull off the drive shaft correct?
  4. Apr 17, 2020 at 6:33 PM
    #44
    splitbolt
    NW Arkansas
    I meant greasing your u-joints...if you have the zerks.
  5. Apr 17, 2020 at 10:05 PM
    #45
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Is the truck downshifting right as you hear this or immediately before doing this? I’m light on brakes, and I hear/feel this. When I hit the brakes a little harder, I don’t hear/feel it. Try that
  6. Apr 17, 2020 at 10:13 PM
    #46
    Sandtaco10851
    SoCal
    2017 Tacoma TRD PRO
    this happens after putting the vehicle into drive or reverse, immediately as I release the brake pedal and from a cold start (or after sitting for approx an hour). That’s the only time that this occurs. It will do it one time and that’s it.
  7. Apr 18, 2020 at 3:49 AM
    #47
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I notice the same “clunking” sound with mine. Only happens once when the truck has been sitting. Thought it had to do with turning left since I always noticed it while turning out of my driveway. I read on another thread here where someone took his truck in over this issue and the tech said the ABS brakes make this sound as the system is activated when the truck gets to 3mph. I believe that’s correct. I tested it and I can control when it happens. Turning, driving straight, it doesn’t matter. Always happens at 3 mph. Looks like it’s a normal sound our trucks make. Test it out and see if yours is the same.
  8. Apr 18, 2020 at 8:41 AM
    #48
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Had some issue's with mine recently since my lift. Noticed mainly coming out of a small incline driveway and turning left. Coming from the left front. a loud pop sound that would happen here and there. After re checking everything the two lower ball joint bracket bolts on the driver side were not that tight. Re torqued and havn't had any issues yet.
  9. Apr 18, 2020 at 5:24 PM
    #49
    TheTaco510
    TheTaco510 Member
    Mine does that same clunking noise and also pulls back and forth without a lift. Took it to the dealership 3 times and doesn’t do it there. A couple days after I use it, it starts once again.
