pops coming from the front hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, May 10, 2010.
  1. May 10, 2010 at 5:04 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    sometimes i hear a wierd popin sound coming from my front hub...i just had it replaced last month....what could it be???:mad:
  2. May 10, 2010 at 5:14 PM
    kinkrider101
    santa barbara
    wheels and tires
  3. May 10, 2010 at 5:18 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I would say ur cv's but your a pre runner, hummm I know in my uncles king ranch there was a little plastic seal that was broken and was making a popping. That would be my only guess.
  4. May 10, 2010 at 5:22 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Could it be the body bushing TSB? 2005 was the year, could have carried over?
    TSB NV007-05 (6/28/05):
    "Some Tacoma vehicles may exhibit a popping or knocking noise from the front or rear of the vehicle while driving on rough or bumpy roads. The No. 2 and No.3 cab mounts have been modified to improve this condition."
    Applicable Vehicles: "2005 model year Tacoma vehicles produced BEFORE the Production Change VINs shown below."
    Production Change Effective VIN:
    NUMMI Plant: 5TE**#2N*5Z074649
    TMMBC Plant: 3TM**#2N*5M002144
  5. May 10, 2010 at 5:27 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    All kinds of stuff: Worn ball joints, play in the CV, loose shock mounts, worn shock, loose bolt somewhere, loose steering-shaft, Loose lug nuts.
    Try to find the situation that replicates it and have a buddy try to pinpoint it.
  6. May 10, 2010 at 5:29 PM
    kinkrider101
    santa barbara
    wheels and tires
    well i had some one stand outside and as i drove forward it was like a pop and a clunk,,,, but it doesnt always happen....i just had the whole left front of my truck replaced by toyota.and its coming from the left side
  7. May 20, 2010 at 8:05 PM
    kinkrider101
    santa barbara
    wheels and tires
    the noises are still going on.......seems to happen when i hit the brakes!!??
  8. May 20, 2010 at 8:40 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Mine "knocks" when turning and backing up
  9. May 21, 2010 at 6:10 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    You sure it's not the brake pads shifting on the pins? A lot of people confuse that with other sounds. It's a very loud metallic "ting" sound. Is yours constant when you're rolling and applying the brakes or happen just once after backing up then pulling forward and hitting the brakes (or pulling forward, stopping, then backing up and applying the brakes)?
  10. May 24, 2010 at 8:59 AM
    kinkrider101
    santa barbara
    wheels and tires
    i can nly hear it when im going slow and apply the brakes
  11. May 24, 2010 at 9:06 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    sounds very similar to the noise a lot of us get from the brake bad float. try backing up and hitting the brakes, then drive forward and apply the brakes. then go forwards and use the brakes again(without backing up this time) if it makes the sound the first time but not the second, i'd say it's the pad movement. if so, it's nothing to worry about.
  12. May 24, 2010 at 9:09 AM
    kinkrider101
    santa barbara
    wheels and tires
    soo i dont need new pads...........it only happens when going forward and hitting the n brakes
  13. May 24, 2010 at 9:11 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well, if the sound happens over and over again when hitting the brakes, and you haven't gone in reverse, it's probably not the pads.
    to answer your question though, pad "float" does not mean you need new pads. all disc brakes have some pad float...you just hear it more frequently in ours
  14. May 24, 2010 at 9:14 AM
    kinkrider101
    santa barbara
    wheels and tires
    i dont know what else it could be
  15. May 24, 2010 at 10:34 AM
    05Moose
    Jim
    I'm still not clear on your explanation as to whether you tried the following. We can ease your concerns for sure on whether it's the normal pad float if you've done the following tests/answered the questions.
    1. Is it happening when you first apply the brakes, or is it constant while applying the brakes?
    2. If it's only happening when you first apply the brakes, you should be able to hear it in reverse too. Pull forward somewhere and stop. Then back up to about 10 mph and hit the brakes. You should hear it the moment you hit the brakes. And it won't be constant. Just a one-time metallic sound.
    I hear it every night when I get home. I pull forward to back downhill into my garage. Coming to a stop in the street going forward will force the pads downward against the mounting pins. But since I've been driving forward all the way home, they're already resting in that position. So no noise at this point. But I then put it in reverse and back down the driveway. I get up to maybe 5 or 10 mph in reverse before I hit the brakes. At that first contact with the brakes, the pads shift up against the mounting pins causing the clunk/ting noise. It's fairly loud. You should be able to duplicate this example and hear them.
  16. May 24, 2010 at 10:45 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I get a popping sound when I turn my wheel to the right while backing up. It's like something is binding and then releasing. Don't think it's the brakes because I greased up the back of the pads. I replaced my old shocks with 5100 shocks and it's still doing it.
  17. May 24, 2010 at 10:50 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    check to make everything is tight from when you installed the 5100s
  18. May 24, 2010 at 11:52 AM
    kinkrider101
    santa barbara
    wheels and tires
    ok thank you i do hear it in reverse now.but sometimes i can hear a ding then like a softer one right after.i will try to take a vid of it
