popular jack to replace OEM for lifted tacos?
Discussion in 'Suspension' started by ComaTosin, May 21, 2009.
  1. May 21, 2009 at 11:35 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    i know that my OEM jack will not lift my truck high enough to change the tire and wondered if you guys were using high-lift or other brand to replace the OEM one. the included tire tool will not work with my current lug nuts either. while i'm on the subject - what are you guys doing for a spare? I have the OEM one under the truck but won't i tear something up if i run it with my newer, bigger tires? can i fit a 285/75/16 under there?
    sorry for all of the Q's. I got on a roll. My search did not turn up much.
    thanks.
  2. May 21, 2009 at 12:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    On my 96 - Hi Lift & I had square tube rock sliders welded to the frame. I used the rock sliders to jack the truck up with. They were stout as hell (rock sliders that is).
  3. May 21, 2009 at 12:22 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I carry a block of wood in the rear of my truck to set my jack on. I have a highlift jack but waiting for the paint for the sliders to dry so i can mount them.
  4. May 21, 2009 at 5:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Oh my block is large as hell. I feel safe
