POR-15 Rubberized Under Coating - Spray Can
Discussion in 'Product Reviews' started by dark tangent, Oct 18, 2011.
  1. Oct 18, 2011 at 12:31 PM
    dark tangent
    dark tangent [OP] Well-Known Member
    Madison, WI
    Rigid Dually D2 Amber Driving LEDs mounted on CBI Offroad ditch light brackets.
  2. Oct 18, 2011 at 7:44 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Damn that is expensive.
  3. Oct 18, 2011 at 8:41 PM
    dark tangent
    Madison, WI
    Sure is, hopefully it's worth it.
  4. Oct 18, 2011 at 8:48 PM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    Why not use the regular POR-15 Rust Preventive Paint, which is much cheaper? What are you using it on? Can you get some before and after pics?
  5. Oct 19, 2011 at 1:42 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    Interesting. Looking forward to the update
  6. Oct 19, 2011 at 12:35 PM
    dark tangent
    Madison, WI
    Yes, I'll take before and after pictures. I guess I wanted to try the spray-on POR-15 because I thought it would be easier to apply. I don't have access to a car lift, just a floor jack and jack stands, so my space under the car is limited.
    We'll see, I might regret it.
  7. Oct 19, 2011 at 12:40 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Get Wax-Oyl instead. From the amount of good reviews I trusted it and I think it looks damn good. We'll see how it holds up over the winter. It's about 16 bucks for a spray can and you'll probably want two for the frame if that's what you're interested in spraying. Rubberized spray will also keep moisture in which will not solve any rust issues.
