Por-15
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SkyHighTacoma, Sep 25, 2009.
  1. Sep 25, 2009 at 12:01 AM
    SkyHighTacoma
    SkyHighTacoma [OP] Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Ok well im going to use Por-15 on my back half of the frame soon (taking off the bed) and then the front half of the frame later on. So i dont have to worry about future rust. But i have a few questions first. What kind of prep is needed (if there is no rust on the frame or if its at its minimal)? Sanding,Cleaning or anything? And if anyone has a writeup on this can you give me the link? And im not 100% sure on how to remove the bed (i think its just those six bolts in the bed) so if you know please tell me? Oh, and what should i buy the super starter kit plus a extra quart,or just the quart? Cause i dont think if you buy just the quart that you get the Metal Ready and the Marine Clean? Thanks in advance. :D
  2. Sep 25, 2009 at 5:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    According to this, all of the paint must be removed before applying the POR.
    http://www.por15.com/Data%20Sheets/no%20read%20directions.pdf
    Check out #7.
    "IF a bead of sweat falls into the can, it is ruined"
    That's some pretty sensitive stuff.
    After it is applied and dried, it must be top coated as the stuff is UV sensitive.
    I would suggest reading all the info HERE.
  3. Sep 25, 2009 at 6:15 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Sep 25, 2009 at 7:00 AM
    jonny
    jonny Betty White Edition Heep ZJ
    thank god for california weather...:cool:
    never had to worry about coating the frame on any of my old vehicles. interested in pics of the process though
    sub'd
    :thumbsup: GL man
  5. Sep 25, 2009 at 7:31 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    I've used POR-15 quite a bit for motorcycle re-builds and it is not as sensitive as they lead you to believe. I think they are just covering their ass. I have applied to directly over slightly roughed paint and it holds up to a wrench dropped on it with no problem. You do have to cover it with a top-coat if it will get sunlight but it's not necessary if it's covered (like your frame). the stuff is great at self-leveling and really looks nice. You will need to clean the surface VERY well, rough it up a bit, then wipe down with denatured alchohol or acetone just to be safe.
    Do pay attention to what they say about clean-up. They are not kidding when they say only time will take it off. Wear gloves, crap clothes, and a respirator.
    Good luck
  6. Sep 25, 2009 at 12:27 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I used POR15 on our Axles for the jeep.
    It's much better on rusted areas and/or cast metal. It's not so great on smooth metal or other areas. If you don't prep it right....it'll peel off.
    Granted - the axles we had were years & years of grease/grime on them and we power washed 'em, used degreaser, used their marine clean, & the metal ready before we applied it. It still peeled off the smooth metal surfaces.
    It stayed pretty good on the badly rusted (not surface rust) and the cast areas (like diffs & such).
    For the amount it costs....I think you're better off using something else.
