porter cable 7424 speeds
Discussion in 'Detailing' started by Divide45, Mar 6, 2015.
  1. Mar 6, 2015 at 8:45 AM
    Divide45
    Divide45 [OP] Member
    I just picked up a porter cable 7424xp and all of the polishing/waxing products I want to use. My question is:
    For those of you who have a PC, what speed works best? I've never used a oribital buffer before. I've only ever hand waxed. Can you give me some tips on using the PC?
    My plan is to wash, clay bar, polish, sealant then wax using all of the Meguiars products. Thanks in advance.
  2. Mar 6, 2015 at 11:44 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    It's somewhat product and pad dependent. If you're going to use it for glazes, waxes and sealants, you really won't need to go over speed 1 or 2. Maybe 3. I dont remember the last time I applied a final step product w/ the PC.
    For polishes, I've never used anything below 5. So go 5 or 6, depending on what you're using.
  3. Mar 6, 2015 at 11:51 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What size pads did you go with? I used to the 6 inch with swirl removers and polishers. And it would constantly stop spinning the proper way. And the swirls would still be there. Once I stepped down to 5 inch pads wow what a difference.
  4. Mar 6, 2015 at 8:49 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    3", 4", and 5.5" low profile pads are absolutely vital for efficient operation. Speed 6 for 5.5", speed 4 or 5 for the smaller pads. Don't forget to apply ample downward pressure.
  5. Mar 7, 2015 at 6:54 AM
    Divide45
    The pads are 5.5" diameter and 1" thick from autogeek
