Possible left side bearing bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerzeyjoe, Dec 12, 2014.
  1. Dec 12, 2014 at 11:15 AM
    jerzeyjoe
    jerzeyjoe [OP] Well-Known Member
    New Jersey
    08 Prerunner 2W
    I have read the threads regarding the wheel bearings. I'm pretty sure my left side is going bad.
    I have a 2008 PreRunner, 2 WD, 75,000 miles.
    Symptoms, while driving straight on highway I hear a rumble type noise. If I turn the wheel slightly left it goes away and the ride feels smoother. Noise appears coming from the left side.
    Questions, should I replace both sides or just the left side?
    Also, should I get the whole assembly, or just the bearing and get it pressed on? I can go to a machine shop and get it done.
    Inner and outer seals, what other parts?
    Thanks
  2. Dec 12, 2014 at 11:55 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I have a '08 DC 4x4 and had the exact same problem. I just replaced the driver's side bearing myself, but took it to a local shop to get the bearings pressed.
    Or you could go with the new assembly. That's what I would have done had I seen the guy selling them on here.
    My original thread: http://www.tacomaworld.com/forum/2nd...n-humming.html
    Bearing/Hub Assembly thread: http://www.tacomaworld.com/forum/2n...ub-solution-ive-done-work-you-save-money.html
  3. Dec 12, 2014 at 11:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Looks like a job for Bamatoy. Give him a ding.
  4. Dec 12, 2014 at 1:27 PM
    devkurf
    devkurf Member at Large
    midwest
    x2
  5. Dec 12, 2014 at 3:32 PM
    jerzeyjoe
    New Jersey
    08 Prerunner 2W
    Order is in. Thanks
