Possible steering issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bilge Rat, Aug 24, 2023.
  1. Aug 24, 2023 at 12:22 AM
    Bilge Rat
    Bilge Rat [OP] Member
    Alex
    SoCal
    2009 Tacoma TRD 4.0V6
    So I have a 2009 tacoma 4x2. Recently I've been hearing/feeling a clunk type sound when going over some bumpy roads. I've eventually kinda narrowed it down to my steering system. I dont notice any negative steering response or anything. My steering wheel does move slightly forward and back if I wiggle it a bit. I've kinda decided it's my intermediate steering shaft but not certain. If I shake it from inside the wheel well. It moves a bit with a rattle. I have a video but not sure if i can atttach it here. Maybe someone can give me some better info. Thanks for any help!
  2. Aug 24, 2023 at 3:40 AM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
  3. Aug 24, 2023 at 7:17 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Get someone to move the steering wheel quickly back and forth (+ - half a turn if they can while engine off) while you put your hand around each joint. You might find a loose u joint on the steering shaft, or a ball joint loose, or the slider bushing on the rack needing adjustment.
    Also do the zip tie mod.
    Geeves77 likes this.
  4. Aug 24, 2023 at 8:18 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Upper steering shaft ujoint is done possibly
  5. Aug 25, 2023 at 9:00 PM
    Bilge Rat
    Alex
    SoCal
    Thanks for the help guys. Been busy so haven't been able to look at it again but will give all these ideas a try soon and post an update
  6. Sep 6, 2023 at 10:01 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Any update on this?
    I think I possibly have the same issue with my truck
  7. Sep 6, 2023 at 10:05 AM
    Bilge Rat
    Alex
    SoCal
    I haven't had a chance to take the truck apart yet to see if I can narrow it down further. Life happens but I'm hoping to get to it rather soon
    4WDTrout likes this.
  8. Dec 12, 2023 at 1:37 PM
    Bilge Rat
    Alex
    SoCal
    Little update. I replaced the steering shaft with pay #45220-04010. Bought an oem replacement for roughly 220. seems to have fixed the clunk sound. Was fairly easy using YouTube videos. Just need an alignment now since my wheel is a tad off. Hope this helps others with a similar issue.
  9. Feb 18, 2024 at 6:27 PM
    Bilge Rat
    Alex
    SoCal
    Kind of a late follow up post but worth a shot. I replaced the upper intermediate shaft. Seems the clunking sound still persists. I saw in some YouTube video that when replacing this, they pull the shaft down before tightening the coupler down to remove the slack. I didn't do that and thinking that could cause the clunking sound. Not sure if anyone is familiar with this at all. Hate stressing about this stuff haha
    4WDTrout and Bishop84 like this.
