Possibly puchasing a 2003 - 6in lift w/35s
Discussion in '1st Gen. Tacomas (1995-2004)' started by hearno, Jul 26, 2008.
  1. Jul 26, 2008 at 8:59 AM
    hearno
    hearno [OP] Member
    Your rearview mirror in the 757
    05 4Runner
    A few.
    I saw a nice 2003 Tacoma V6 with a 6inch Fabtech lift and Weld rims with 35's on them. Im currently going back and fourth on the price but I'm concerned because I'm not familiar enough with these trucks and lifts to know what to look for. It has about 60k miles on it. It has an auto trans and an extended cab. Any advice is appreciated.
  2. Jul 26, 2008 at 9:33 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Pics? Link?
  3. Jul 26, 2008 at 9:34 AM
    hearno
    hearno [OP] Member
    05 4Runner
    A few.
    Im just looking for advice.
  4. Jul 26, 2008 at 9:37 AM
    TPPJR
    TPPJR Member
    Washington State
    4x4
    Has the gearing been changed in both front and back to accommodate the larger tires? Has the speedo been adjusted also if not the mileage/speed will be off by about 20% or so.
    Thomas
  5. Jul 26, 2008 at 9:47 AM
    hearno
    hearno [OP] Member
    05 4Runner
    A few.
    Change the gearing? You mean the rear axle gears? Im not worried about the speedo... I can calibrate the truck myself. If the gears haven't been changed, is it worthwhile? Expensive?
  6. Jul 26, 2008 at 9:52 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Pic's help get advice. ;)
  7. Jul 26, 2008 at 9:55 AM
    TPPJR
    TPPJR Member
    Washington State
    4x4
    I mean axle gears in the front and back. If you only change the back you will not be able to use four wheel drive. If he hasn't changed the gearing the truck will most likely be very underpowered (was with my '87 but it did only have a 2.4l) I have recently purchased an '04 and in fact this is my second post. Just lurking here to see what is up with the newer first gen trucks. For the most part the gears have to be changed by a professional since some specific setup tools are required. It will bring some life back into the truck but with the drawback of being weaker. There is ALWAYS something else affected by everything you do and it usually isn't in a good way!!
    Thomas
  8. Jul 26, 2008 at 10:06 AM
    Khaos
    Khaos Big Member
    Bryant
    This is why I wanted to see the truck and read the physical add.
    I am a professional at shopping on Auto trader. More like addicted to Auto Trader. But whatever.
