post coilover install Q's
Discussion in 'Suspension' started by blkcoma32, Sep 20, 2009.
  1. Sep 20, 2009 at 3:11 PM
    blkcoma32
    blkcoma32 [OP] Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    Well, i got my SAW coilovers installed and i have a major (i think it is camber) issue (top of wheel tilted out) I know that TC UCA's are supposed to fix this but i don't really want to drop the coin for those when i am possibly going to do a SAS in the next year or so. So i guess my question is, is there a cheaper way to correct this? I have seen some lift kits come with a crossmember replacement that i assume is to correct this but idk. Was also wondering if the only thing that will alleviate the stress on my CVs is a diff drop? Thanks
  2. Sep 20, 2009 at 5:22 PM
    blkcoma32
    Illinois
    Anybody?
  3. Sep 20, 2009 at 6:34 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Did you get an alignment after the install?
    If after the alignment you still have the positive camber and the adjustment is maxed out for camber and you don't want to buy arms, only thing you can do is lower the coilovers down to bring the camber back into speck. The more you lower the coilovers, the better your positive camber will get.
  4. Sep 20, 2009 at 6:43 PM
    blkcoma32
    Illinois
    It has not been aligned yet but i did not know u could adjust the camber, how does it adjust?thanks for the input man
    Anyone Else have any input?
  5. Sep 21, 2009 at 2:12 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    dont crank the CO's down so much and get an alignment done by a shop, dont try to do it yourself
  6. Sep 21, 2009 at 7:41 PM
    blkcoma32
    Illinois
    I have them set at 2 1/2, Ihave to have 2 1/2 to fit my 33's, so i should get the front diff drop?
  7. Sep 21, 2009 at 7:51 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    There are other cheaper alternatives to ucas than the total chaos ones. Camburg has a uca that utilizes the stock ball joint.
  8. Sep 21, 2009 at 8:05 PM
    blkcoma32
    Illinois
    The camburgs arent made to correct alignment, it says that in one of the suspension stickys
  9. Sep 21, 2009 at 8:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Get it aligned. All the adjustments are done via the Lower Control Arm.
  10. Sep 21, 2009 at 8:07 PM
    blkcoma32
    Illinois
    so getting it aligned should take care of most of the camber problem?
  11. Sep 21, 2009 at 8:09 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
  12. Sep 21, 2009 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should. Your gonna be short on Caster, but the Camber and Toe should be eaily put back in spec.
  13. Sep 21, 2009 at 8:11 PM
    blkcoma32
    Illinois
    is short on caster better than bad camber?
  14. Sep 21, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think so. Bad camber is gonna wear the tire on the edges.
  15. Sep 21, 2009 at 8:19 PM
    blkcoma32
    Illinois
    Thanks Chris, I'm Chris too by the way!
  16. Sep 21, 2009 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nice! Glad to help, Buddy. :)
  17. Sep 22, 2009 at 8:07 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    the camburg UCA's will correct alignment probs. mine did. but get it aligned first, then see about buying some UCA's
