Post off-roading/trail riding maintenance and cleaning??
Discussion in 'Off-Roading & Trails' started by x2468, Jun 24, 2010.
  1. Jun 24, 2010 at 10:58 PM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    Hey guys, Just picked up an 02 TRD 4x4 taco the other day. Did my first little off-roading excursion this morning, had a lot of fun. Because im in S. FL a lot of it was in sugar sand, which i know can be a bit corrosive if it gets into places it shouldn't. Immediately after getting back to civilization me and my buddy sprayed the truck down, in the wheel wells and under the undercab. I know from atv and enduro dirt biking not to use a very high pressure of water as to not force any dirt/sand into places it otherwise wouldn't end up. Is there any other part of the truck I should clean? I didn't get a chance to do the engine bay but i'll do that next. Should I do the air filter? Is there a certain way I should clean anything?
    What about post off-roading maintenance? Should I grease or lube anything after washing?
    I did a search and found a few threads about pre-off-roading maintenance but couldn't find anything on post. Thanks,
  2. Jun 25, 2010 at 12:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Cleaning...that's about all you can do.
    Offroading doesn't add much additional maintenance - Check your owners manual for maintenance intervals. You might want to follow the "Extreme Conditions/Towing" recommendations.
    Air filter? Check it each time.... Buy yourself a washable filter (keep the original one) and clean the air filter twice a year atleast or sooner if needed.
    If you're running any water/mud - do some research about extending your diff breathers. This modification will help prevent water from getting inside your diff oil.
    Offroading is hard on vehicles. You've gotta understand, that regular offroading is going to make things wear faster. Water/mud gets in seals & bearings and there's no way you can prevent that. It's a part of wheeling. Depending on how much wheeling you do, will depend on what types of maintenance & repairs will pop up over time. You just don't know...
