Post your 265/75 16s!
Discussion in 'Wheels & Tires' started by littlezav, May 29, 2017.
  1. Apr 29, 2021 at 7:48 PM
    #1521
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    265/75/r16 KO2’s on 16x8 fifteen52 turbo mac’s.
  2. Apr 30, 2021 at 2:06 PM
    #1522
    jstj0sh
    jstj0sh Member
    Magnolia, TX
    2018 MGM Tacoma TRD OR 4x4
    Total tire noob here. Just found this thread and am doing a little sifting through the pages to see if there's an answer, but I'm on stock 2018 TRD OR rims looking at either Toyo AT3s or Wildpeaks (surprise surprise).
    I'm wondering if bumping up from a 265/70R16 to a 265/75 will bite me in the ass later if I have to throw the spare on or if there's any other ramifications that I'm not taking into consideration...
  3. Apr 30, 2021 at 3:07 PM
    #1523
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Not the sexiest/most aggressive tire, but I'm pretty sure those are what I'm getting next after my Toyo Open Country R/T's wear out. They look great but get louder with wear. I also commute fairly far for work so that's a big part of the consideration.
    RobEd[QUOTED] likes this.
  4. Apr 30, 2021 at 7:01 PM
    #1524
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Whenever you change tire sizes you definitely want to change the spare size.
    Or... Get a plug kit, air compressor and hope when something does puncture one of the tires it’s not in the sidewall.
    I’d get 5 tires though
    jstj0sh[QUOTED] and TRDProBuddy like this.
  5. May 2, 2021 at 11:38 AM
    #1525
    Fat Tal
    Fat Tal Member
    Maryland
    2021 TRD OR
    KO2's 265/75R16; OVTune
    Here is my taco. KO2's 265/75R16, stock wheels, no lift. I like the stance enough not to bother with $$$ and complications of a lift kit and bigger tires.
  6. May 2, 2021 at 1:43 PM
    #1526
    Vorra65
    Vorra65 Well-Known Member
    That looks good brother, just picked up my 21 DCLB SR5. Thinkin this is the route I’m going, stock alloys with 265/75R16 and no lift. Very sanitary.....
  7. May 2, 2021 at 8:27 PM
    #1527
    str8edgMTBMXer
    str8edgMTBMXer Well-Known Member
    Central Ohio
    2021 SR5 DCLB; midnight black metallic
    probably doing the same size with my SR5...no lift etc. Will be getting Cooper Discoverer AT3 4S's or Dick Cepek Trail Country EXP's
    Fat Tal[QUOTED] and onesixonetwo like this.
  8. May 8, 2021 at 7:33 AM
    #1528
    DB88
    DB88 Member
    Canada
    2025 TRD Off RD Premium
    Falken Wildpeak. what a difference from the stock tires..64212198997__42EF4CCF-3DE9-4E72-AE9E-D2783C5394EB.jpg
  9. May 15, 2021 at 10:54 PM
    #1529
    NeraMezzanotte
    NeraMezzanotte Well-Known Member
    Farah
    Orange County, CA
    2019 Tacoma TRD Off-Road 4x4 DCSB 6-Spd M/T (MBM)
    I am currently in the market for Continental Terraincontact A/T tires (primarily for their outstanding dry cornering & braking grip on tarmac), and am on the fence with regards to going either P265/70r16, or shifting up to P265/75r16 (currently on the factory Goodyear A/T Adventure + Kevlar P265/70r16).
    I generally prefer a form-follows-function approach to my vehicles, and the only reason I would truly be choosing the 75 aspect ratio (a/r), aside from its increased performance potential off-road (although the truck spends 95%+ of its time on the tarmac), is for improved aesthetic regarding proportionality (31.3" tire on a 16" rim) which lends itself to that 'meaty look' many of us seem to enjoy. On tarmac, in theory, a 70 a/r tire will out perform a 75 a/r tire (identical tire model, section width & load rating) due primarily to its reduced rotating mass, stiffer sidewall (P-to-P, or LT-to-LT), and increased tread width (most tires of an identical model with identical section widths will have about a +1.2-4.7% increase in tread width with a -5% a/r). Added benefits to the 70 a/r is that speedometer reading remains exact, and I do not have to worry about the spare tire disparity.
    So essentially, I have come to the 265/75r16 council to understand from those who have gone from P265/70r16 -to P265/75r16, whether or not you experienced any noticeable shift in grip under cornering or braking, as well as with general ride performance. Most likely the majority of you have changed tire brand (and possibly load rating) when making the shift, however, I am curious to understand the general consensus. Clearly, if anyone has made the shift to an identical brand, model and load rating (with just the a/r increasing), your input would be invaluable.
    Thank you for reading, and I appreciate your time in giving any insight!
    Cheers.
    PS. Anyone who has experienced the Continental Terraincontact A/T, your input on general experience is greatly welcome.
  10. May 15, 2021 at 11:05 PM
    #1530
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Went with Goodyear Wrangler Ultraterrain's. Love them so far.
  11. May 19, 2021 at 5:54 PM
    #1531
    Bammer55
    Bammer55 Active Member
    That looks great! Same set up I want to run just concerned about the stiffer ride and how much the extra rotational weight will affect power? Can you comment on the ride quality/power performance? Also what psi are you running?
    Truckkiller likes this.
  12. Jun 11, 2021 at 6:45 PM
    #1532
    RobEd
    RobEd Well-Known Member
    Rob
    Louisiana
    2017 Black SR5 DCLB
    TRD Pro grille, Blacked-out badges and rear bumper
    Finally! Over 2 months after I received the ‘20-21 TRD Pro wheels, the backordered center caps came in.
    Had them installed this morning, wrapped with 265/75r16 Cooper Discoverer AT3 4S, along with a 1/4 inch strut spacers, which lifted the front about a 1/2 inch. With the taller tires, the truck sits about an inch taller up front and 1/2 in the rear.
    Also with the offset of the wheels and wider tires, the outer edge of tire sticks out about an inch more.
    I think it looks great!
    Promised the wife that this is my last mod.
    1BBFD904-F898-42E8-880B-66D6EF7722A9.jpg 7D78D7AE-E90B-4959-B8B8-4C6017A1E09E.jpg ABAA725B-0B7D-45BC-9EA9-093BF2E9B19E.jpg AE722ECE-D414-4A09-9FB9-DA30A66B9FAF.jpg 45B4810D-FF04-4A6B-85E8-9B399688CF2B.jpg
    6MTPro, Dr. Doom Says and trailbound like this.
  13. Jun 11, 2021 at 6:50 PM
    #1533
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    KO2
    Polythemus and trailbound like this.
  14. Jun 11, 2021 at 10:27 PM
    #1534
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    Looks Great, Hope the ride is good.
  15. Jun 12, 2021 at 6:18 AM
    #1535
    TNFishyTaco
    TNFishyTaco Well-Known Member
    Cory
    What lift kit is that?
  16. Jun 13, 2021 at 5:55 PM
    #1536
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    It is the factory suspension that comes on the TRD Pro but I have the ICON Progressive AAL with the overload spring left in
  17. Jun 22, 2021 at 7:06 PM
    #1537
    mattspiral8
    mattspiral8 Active Member
    2021 Tacoma Off-Road
    To anyone who is running on the BFG KO2s, how much stiffer is your ride and do you feel alot of sluggishness from it? i would have loved a C load KO2 but on 265/75/16 only one available is the E. Is there really that much of a difference in stiffness from the oem goodyear tires?
    texbaz likes this.
  18. Jun 23, 2021 at 6:14 AM
    #1538
    Xero
    KO2. Front end has Bilstein 5100 on the 5th notch and rear has an Icon 3 leaf with 5100.
    Mrod18, MuleyCrazy13 and trailbound like this.
  19. Jun 23, 2021 at 5:23 PM
    #1539
    texbaz
    "Buffalo Creek" TX
    From what I Have read through out TW, its like 50/50. Some say they are fine,others just lower the pressure to try and compensate for the additional ply's and load rating.
    try this thread lots of threads like this.
    https://www.tacomaworld.com/threads/choosing-265-75-r16-over-275-70-bfg-ko2s.520361/
  20. Jun 24, 2021 at 12:56 PM
    #1540
    Johnknwd
    Johnknwd Member
    2017 OR Stock wheels no lift. 265/75/16 Goodyear Duratrac
    Mrod18, trailbound and CemenTRDgen like this.
