Power at Cigarette lighter with key off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TRDSPORT, May 8, 2012.
  1. Aug 31, 2016 at 6:23 AM
    #41
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Yes I did, once you pull the relay its pretty strait forward. Pull the relay, and twist a real thin with from one terminal to other, reinstall and you set. Obviously it is right around a year for me and no issues. I initially tried the stuffing the relay to force contact, but that was not reliable at all. Jumper it is very easy and worth while.
  2. Aug 31, 2016 at 6:40 AM
    #42
    RugglesTarlek
    RugglesTarlek Well-Known Member
    California
    basic basic basic 14 AC
  3. Mar 2, 2017 at 9:53 AM
    #43
    jslum
    jslum Well-Known Member
    jason
    SoFL
    Just found this and am so stoked it's worth a bump. I could have soldered mine but I just cut a piece of credit card, folded it in half and shoved it in there. It's just long enough that the plastic housing on the relay holds it in there tight. If it doesn't work after a while I will go back in and solder it but plenty of guys are getting by with paper in there so hopefully it's good. Entire process took less than 10 minutes
