Power ECT
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ptowntaco, Nov 10, 2010.
  1. Nov 10, 2010 at 11:08 PM
    Ptowntaco
    Ptowntaco [OP] Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    I could not find anything about my question with the search... I was wondering is it better for your truck/MPG to drive with it on all the time? Also will it harm anything over time?
  2. Nov 10, 2010 at 11:39 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    there was a thread on this like 2 days ago
  3. Nov 10, 2010 at 11:49 PM
    Ptowntaco
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Really? my bad i cant find it in the search...
  4. Nov 11, 2010 at 12:10 AM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    My ultraguage shows there isn't that much difference in mpg. And it shifts easier up and over hills and overpasses. I don't use it though. If it helped then it would be one of those obvious things that we all learned about when we first got our trucks. Just keep it off and enjoy your slow truck Bryce :D
  5. Nov 11, 2010 at 10:11 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
  6. Nov 11, 2010 at 4:53 PM
    Ptowntaco
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Lol thanks Jake.
    Sorry I guess I am just not good at searching...
  7. Nov 11, 2010 at 4:54 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Ha... Searchbar fail!
  8. Nov 11, 2010 at 5:23 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ive found that ECT on or off makes no difference when you drive with a regular/light foot. ECT Power on just lets the trany stay in a lower gear more easier. With power off, even when you get heavy on the gas, the trany tends to upshift too soon and is sluggish to down shift. Therefore, ive found it much easier to drive with Power on.
    As far as gas mileage, With Power off, I tend to get lower gas mileage when Im trying to drive hard and the same gas mileage when I drive easy. Again, this is why I keep Power on.
    Hope this helps.
  9. Nov 12, 2010 at 6:05 PM
    jvallin
    jvallin Well-Known Member
    joey
    turlock CA
    01 Dcab SR5 4x4
    K&N intake, Magnaflow, HID conversion, 265/75/16 MT, PIAA driving lights, Optima red top, billstein 5100's @ 2.5 and pro comp 2" AAL.
    it will change the shift points of the transmision and make it hold gears for a longer time. It also prevents the torque converter from unlocking so soon. It will drop your mileage a little. if you are towing or driving in the mountains though you will have lower tranny temps with it on and more power. It wont hurt anything to run it all the time but there really is no need.
  10. Nov 12, 2010 at 8:00 PM
    YouNext
    YouNext General Calamari
    San Diego
    K&N FIPK, Gibson Exhaust, Doug Thorley Headers, URD pulley, Stoptech Cryo-treated Slotted Rotors, Deaver J59, Bilstein 5150s, Total Chaos LT (w/Spindle & Tower Gussets), Icon LT C/Os.
    As already mentioned it extends the shift points on your automatic transmission giving you that little extra power/response.
    The Tacoma Manual says to keep it off for optomize fuel efficiency.
    I find it most useful in offroad and rush-to-work situations, otherwise i leave it off.
  11. Nov 13, 2010 at 9:03 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    I leave mine on all the time and get better mileage with it on. Give it a try, it won't hurt anything.
