Power Gate anyone?
Discussion in 'Technical Chat' started by SilverSeven, May 7, 2009.
  1. May 7, 2009 at 8:45 AM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    anyone have experience with the power gate isolater?
    This simplicity is appealing to me
  2. May 7, 2009 at 10:45 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Why do you need the isolator?
    The only thing it's preventing is you draining your main starting battery while still using your accessories (compressor, winch, stereo, lights, etc) with the car off.
  3. May 7, 2009 at 2:12 PM
    SilverSeven
    Jordon
    South Jurzee
    2 batteries
  4. May 7, 2009 at 2:15 PM
    johnecon2001
    Phoenix, AZ
    Right, but what is your purpose for running two batteries? Did you need more power? Or did you not want to drain the starting batt?
  5. May 7, 2009 at 3:09 PM
    SilverSeven
    Jordon
    South Jurzee
    ohh sorry, yeah going to power all acc off 2nd bat... use 1 for starting and winch only
  6. May 7, 2009 at 3:30 PM
    johnecon2001
    Phoenix, AZ
    Perfect then. There seem to be a lot of programmable options on the Powergate, but a simple relay/solenoid would do the job too.
    Even an R/V isolator would work.
  7. May 8, 2009 at 8:10 AM
    SilverSeven
    Jordon
    South Jurzee
    do you reccomend any? i dont know a lot about this shit.. just want a solid dual battery set up.. I will be running a ST 12 circuit fuse box
    I dont know what battery to get or anything else
  8. May 8, 2009 at 1:00 PM
    SilverSeven
    Jordon
    South Jurzee
    so how did you fit all that shit on the battery terminals?
  9. May 8, 2009 at 1:19 PM
    johnecon2001
    Phoenix, AZ
    There's a Blue isolator that Checker sells that will let you charge both batteries without drawing from both of them.
    Also, something I've been contemplating on getting is the Blue Sea fuse box:
    http://shop.ebay.com/items/_W0QQ_nkwZblueQ20seaQ20fuseQQ_armrsZ1QQ_fromZQQ_mdoZ
    Waterproof, several sizes, etc etc.
    Once you get that, run one line from the positive battery terminal and on from the negative to the new fuse box. Run the accessories out of the fuse box.
    Edit, the isolator is made by a company called Sure Power. Warn makes a couple too.. but they're three times as expensive.
  10. May 8, 2009 at 2:31 PM
    SilverSeven
    Jordon
    South Jurzee
    silverback, you have so many parts in there that i hate to ask you to list, but what do you say about assembling me a kit and selling to me?
  11. Dec 18, 2011 at 2:47 PM
    Dr. Sleep
    Dr. Sleep Well-Known Member
    Shane
    Colorado
    07 DoubleCab SR5 4X4
    I realize this is an old thread . . . but just FYI. I purchased a 200 amp single rectifier (Isolater) from Perfect Switch LLC, the maker of the Power Gate battery isolaters seen here: http://www.perfectswitch.com/ I had 2 of these fail after about a year each. The good news is that Scott Stolper at perfectswitch.com is excellent with his customer service and is replacing the 2nd failed unit as well. The bad news is: 2 failed units.
