Power loss
Discussion in '2nd Gen. Tacomas (2005-2015)' started by William S, Jun 12, 2012.
  1. Jun 12, 2012 at 9:08 AM
    William S
    William S [OP] New Member
    william
    Maine
    07 TRD Sport
    Re- my 2007 Tacoma TRD Sport: Since I had my accelerator replaced and software upgraded on safety recall, I have been experiencing intermittent power loss. I am told that the software upgrade cuts back on fuel pressure when both brake and accelerator are pressed simultaneously. But this power loss occurs randomly when only the accelerator is depressed, and the best way to bring it out of this condition is to pump or floor the accelerator. Very aggravating under certain road conditions. Toyota has no answers, my dealer kept the truck over a week with no fix. I have not found anyone with same complaint.
  2. Jun 12, 2012 at 9:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    I hope you find the fix. This is the first I have heard of that issue. A lot of members on this board refused the "fix".
  3. Jun 12, 2012 at 4:43 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    Why did you have to have that replaced? This wasn't for the stuck accelerators or whatever from years ago was it?
  4. Jun 12, 2012 at 4:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yep
  5. Jun 12, 2012 at 5:02 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Hmmm. I haven't done any of the notices they have sent me. I usually just throw them away. I am interested in the spiral cord one or whatever that they sent me a letter for however. Think I'll have to tell them to not touch the pedal when I take it in?
  6. Jun 12, 2012 at 5:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    If you don't want it done, yes. They may make you sign a waiver though.
  7. Jun 12, 2012 at 5:13 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Alright cool. I'll make a mental note for that because I haven't had any accelerations issues with my truck and do not intend to have them "fix" it so that I do :\
  8. Jun 13, 2012 at 3:43 AM
    William S
    william
    Maine
    07 TRD Sport
    Yes, it was part of that sticky accelerator mess. Dealer recommended fix, said new software upgrade was important. I had no trouble with floor mats, as I use the HD rubber mats. I am convinced the software upgrade is the culprit here, but my issue is apparently unique only to my truck. Otherwise, I Love the truck!
  9. Jun 13, 2012 at 4:07 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    SoCal - Fontana
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    the ecu flash made it so that if the accelerator pedal is being depressed, and then the brake is pressed simultaneously without releasing the accelerator, then the computer overrides the gas since it is an electronic control and not fly-by-wire design. I You are not the first person I have seen complain of this problem on here. I myself had the recall done and have had no problems. Anyways, I have never read about a dealer being able to correct the problem or even duplicate it for that matter, but what it sounds like it 1 of 3 things. Either:
    A) your ecu flash caused a problem that is making this new software kick in randomly and decrease power or because it thinks the breaks are being applied.
    B) you are driving with 2 feet or your foot is hitting the break without you knowing it and the override is kicking in
    or C) your traction control is messed up and decreasing engine power
    Thats all I can think of though. GL
  10. Jun 14, 2012 at 3:24 AM
    William S
    william
    Maine
    07 TRD Sport
    I am positive it is not item B, so it may be A or C. Thanks for the ideas! William S
  11. Jun 14, 2012 at 7:56 AM
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    Have you ever had your fuel injector cleaned? I just had the dealer do my truck for the 2d time 35K and 75K after each time my truck runs smoother and like new power.
    I also have the new accelerator and software upgraded. The new software did change my truck. I'm happy that some of the engine braking has been smoothed out. "I was getting whiplash in LA stop and go traffic" now my truck will cost a bit longer before it kicks in.
    My dealer cut way to much off my accelerator so I got the hole new one.
  12. Jun 14, 2012 at 8:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Found this out after they cut up my gas pedal. I went in mainly for the free mats that came with the recall since I had a cracked drivers mat leaking fluid thru to the carpet. Later I had them install the revised pedal (non hacked version) just because, and Toyota ended up giving me a $100 credit for Toyota parts for my troubles :D
  13. Jan 30, 2013 at 2:41 PM
    dmck
    dmck New Member
    Colorado
    Tacoma TRD Sports
    2012 TRD Sprt. From dead stop allows speed up to 20 mph and then acts like I turned the key off; last for almost one second. Intermittent and I no "eng ck lite". This power loss is scary tying to enter on-ramp, but I'll have to live w/it. I did get a maint. number and the factory rep said Toyota will fix problem as long as I own the truck; they just have to duplicate it.
  14. Jan 30, 2013 at 5:13 PM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    2012 TRD sport also. Mine is a manual Access cab. Had it happen one time to me also. It was a couple days after doing a stereo install where I had the battery disconnected. Was accelerating up a steep grade and the power just stopped. At first I thought the engine died. I saw no dash lights come on. The stereo was still playing. After checking my feet and shifter position I pumped the throttle a couple times and it came back to life. I had no throttle for at least 5 - 8 seconds. Never experienced anything like that before or since.
  15. Jan 30, 2013 at 6:15 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The brake switch takes a 1/4 turn to unclip, slide up or down to desired position, then 1/4 turn to lock again.
    Before trying to adjust it, see if you can get the brake lights to come on by wiggling the pedal or depressing it less than 1/4 inch. If they light up under those conditions, you've found your culprit. Its starting to be a common complaint, and the brake pedal switch adjustment has been at fault in at least a few cases on this forum.
