Power outlet relay fusebox
Discussion in '1st Gen. Tacomas (1995-2004)' started by ProjectEric2.0, Mar 6, 2019.
  1. Mar 6, 2019 at 9:20 PM
    ProjectEric2.0
    ProjectEric2.0 [OP] Well-Known Member
    Eric
    2003 toyota tacoma 2wd standard cab 2.4L
    Interior paint, LED lights, speedometer projector, tinted windows
    So looking at some youtube videos says relay should have a diagram to indicate circuit 30, 85, 86 and 87, but after pulling mine out from my 2003 tacoma base cab 2.4 there is no diagram. How do I test this relay? I have no power on cigar lighter and outlets including radio. Dome light yes. I already checked fuses and are good.
  2. Mar 7, 2019 at 12:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It should tell you what pins are what in your electrical wiring diagrams for your truck .
    Which you should have doing all the Electrical work you are.
    The 2 nickle blades are the coil the 2 copper are the contacts
    Use a 12VDC power supply to energize the coil your contacts will pull in if every thing is working
    used fused jumper leads to protect things if there is a problem
    cruiserguy likes this.
  3. Mar 7, 2019 at 6:23 AM
    ProjectEric2.0
    Eric
    Im a novice. Maybe Should stay away from electronics. No diagram. Only thing I found was below which I can barely understand. I guess i could go to autozonee and see if new relay has diagram as maybe mine faded...
  4. Mar 7, 2019 at 7:01 AM
    Glamisman
    Glamisman Well-Known Member
    this is the diagram you need for the Power outlets.
    pin 5 power all the time
    pin 1 appears that only has power with the key in the accessory position.
    pin 3 goes to power outlets.
    pin 2 to ground.
    it appears that the power outlets only work with the key in the ACC position? odd if that is how it works.
  5. Mar 7, 2019 at 7:19 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    at least the 01-04 are designed this way. without the key in ACC there is no power to the outlets (any of the 3)
    I actually prefer this method over "always on"
  6. Mar 7, 2019 at 11:07 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I won`t touch a Vehicle without the wiring diagrams much to frustrating
    best of luck
  7. Mar 7, 2019 at 4:20 PM
    ProjectEric2.0
    Eric
    Its 4 pin. Ciruit tester light turns on for one of copper pins. Other copper does clicking, but not constant. Other 2 nickel pins light does not turn on. Going to see if autozone has this part to test new power outlet
  8. Mar 8, 2019 at 4:49 PM
    ProjectEric2.0
    Eric
    Its not power outlet relay (R6)
  9. Mar 9, 2019 at 6:13 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    OP,
    There is a mod you can do to make the outlets hot with the ignition off. Try that 1st to verify there aren't any other issues before purchasing a new part.
    EDIT:
    Here is mine:
  10. Mar 9, 2019 at 9:44 PM
    ProjectEric2.0
    Eric
    My dad found the probelm and fixed it without me... out of town today so will update this post later.
  11. Mar 13, 2019 at 3:36 PM
    ProjectEric2.0
    Eric
    It's alive! There is now power on regular sockets. I messed with some cables (push in) and now there is light. Cables under shifter covered in velcro/foam so couldnt see harnest. That or just a miracle.
  12. Mar 13, 2019 at 4:50 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Gosh dang it, I wanted you to fix it. But at least it's fixed. What'd he find? A connector unplugged? Bad ground? Curious minds want to know.
  13. Mar 13, 2019 at 6:17 PM
    ProjectEric2.0
    Eric
    My dad will show what wires were cut on Saturday so ill update then. As of today i got power on lower 2 power sockets either by luck or the 2 harness i pointed at in the pic above. Hope it stays that way when re-assembled.
    cruiserguy[QUOTED] likes this.
  14. Mar 17, 2019 at 8:16 PM
    ProjectEric2.0
    Eric
    He worked yhis weekend. Here is how it looks lit
