Power outlets always hot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rellik01, May 23, 2012.
  1. May 23, 2012 at 3:46 PM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    I just realized that the 2 power outlets in my 2012 are always "hot" is this common or some kind of fluke.
    thanks
  2. May 23, 2012 at 3:48 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    My 2011 aren't.
    Frank
  3. May 23, 2012 at 3:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hot as in temp or hot as in always has power to them?
  4. May 23, 2012 at 3:53 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea if you mean they have power to them, they either changed something with the 2012's or something is goofy with yours. Mine only have power with the ignition on.
  5. May 23, 2012 at 3:55 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I know in my 06' the ignition has to be one and the button has to be pushed in order for it to get power to it.
  6. May 23, 2012 at 4:03 PM
    jtav2002
    Josh
    Reading, PA
    Yea same with my bed outlet as well, not sure if he's talking about that one or the ones inside.
  7. May 23, 2012 at 6:21 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    they are only on "hot" with the key in my 12.
  8. May 24, 2012 at 9:56 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I think he's talking about the 12v interior power outlets. If that's the case OP then someone did the 12v anytime mod for you already so be glad you just saved about 5min of your life from having to do that yourself. This is how they should come wired from the factory and the only time this is an inconvenience is if you have a radar detector or similar that runs on 12v power and you want it to turn off with the ignition.
  9. May 24, 2012 at 1:47 PM
    Rellik01
    Craig
    Windermere, Florida
    Hot as in power on. I doubt anyone did a mod to the truck as it had 9 miles when i picked it up.
  10. May 24, 2012 at 1:51 PM
    Ostrichsak
    Jer
    I saw that after I posted and figured it would be pretty unlikely for it to be modded. The only other possible explanation is a faulty relay from the factory. Your relay for this is always open so it's not interrupting the circuit the way it's supposed to. Most likely it won't cause any issues down the road because of how it's wired (failure causes it to work all the time rather than not work at all) so it's completely up to you if you want to take it into the dealer for warranty work. Are we 100% sure that ALL 12v outlets in the new trucks are supposed to be switched? I've had cars in the past that had one switched and the other constant. This was the best configuration IMO so that you had the best of all worlds and I'm not sure why other manufacturers don't follow suit other than switched outlets are dummy proof.
  11. May 24, 2012 at 2:12 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This is the wiring diagram for a 2009.
    Fullscreen%2520capture%25205242012%25202_20b1f7a9af6ef09671ced39fa510748d85cb70f9.jpg
  12. May 24, 2012 at 2:33 PM
    Doc35
    Doc35 Well-Known Member
    Doc
    Virginia
    2012 DC MGM TRD Sport Prerunner
    Mine aren't hot, when I turn off the ignition my gps asks if I want to continue on its internal battery.
  13. May 24, 2012 at 3:37 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    Yeah on my 12 DCLB the power cuts off when the key is turned off.
  14. May 24, 2012 at 3:58 PM
    Ostrichsak
    Jer
    Yeah, that's my vote too. In order to have the same thing I had to take down my lower kick panel, access the fuse block & pull it down to get the relay off of the back side, take it out of the fuse block, pry off the little cover to wedge a little piece of plastic into the connector and then reverse the whole order. To just luck out and get a truck that already did this would have saved all that effort.
  15. Jun 27, 2012 at 9:28 AM
    SilverBullet07
    SilverBullet07 Silver Member
    Bryan
    Pleasanton, CA
    Silver 07 PreRunner Sport
    Tint, Grillcraft Grill, Leveling Kit, Retrofit Headlights.
    Do you know where I can find the how to do this mod? I've been looking for it since I have a light that I need to flash when my truck is not on and I dont want to leave my keys in my truck to do that.
    Thanks in advance
  16. Jun 27, 2012 at 9:36 AM
    FLAJIM
    FLAJIM Well-Known Member
    Jim
    Daytona Beach, Fl.
    2012 PreRunner SR5 2WD
    ARE tonneau cover, Electric Pop & Lock tail gate, 2 lighter plugs in bed, Reese hitch/ factory wiring, OEM Bed Extender and fog lights.
    I would like it, but my goes off with the key on my 2012. When I put my bed plugs in, I pigtailed off for the cab for the GPS and cell phone. Now all 4 "extra" plugs are fused and "live" all the time. Been doing it for years in other vehicles. Never had a problem with a dead battery but I am careful with them. I also did the same with my Harley putting a LIVE plug in the tour pak. Comes in real handy.
    Be Safe JIM
  17. Jun 27, 2012 at 9:49 AM
    Ostrichsak
    Jer
    Check the thread sticky at the top of the 2nd gen subforum because I think that's where I found it. 12v anytime mod or something. Plenty of mods in there to keep you busy.
  18. Jun 27, 2012 at 1:10 PM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    When I first got my 2012 the outlets were only on when Turned the key on. So I installed an always powered one in the glove box. Just recently noticed my factory outlets have power all the time now. Must be a stuck relay too! I doubt I'll want to fix that lol.
  19. Jun 27, 2012 at 6:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would be careful with a stuck relay. If it isn't making a good connection on the contacts ( high resistance ) it will act like a heater and could burn or melt. It would be better if you just hot wired around the relay contact, safer too.
  20. Jun 27, 2012 at 6:42 PM
    Ostrichsak
    Jer
    If their relays failed it failed open so there's no connection. Nothing to worry about. The way these particular 12v outlet relays are set up is when the truck is on they open allowing the outlets to be on so that if they should fail it will leave the user with constant 12v rather than nothing at all.
