Power shift a stick?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colton1219, May 16, 2011.
  1. May 16, 2011 at 1:49 PM
    colton1219
    colton1219 [OP] Active Member
    Arizona
    SR5
    4.88 gears, ArB Bumper, ARB lockers front and rear
    Anybody have expierience with powershifting a 4.0 6speed tranny? Been doing it for years in all my dodge cummins and never had a clutch or throwout bearing problem ,How about the tacomas ?
  2. May 16, 2011 at 1:51 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    What's the point? It's not a racecar.
  3. May 16, 2011 at 4:00 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    x2
  4. May 16, 2011 at 5:57 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Drive how you like. The clutch serves the same function as power shifting, to break torque.
  5. May 16, 2011 at 6:33 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    I don't have any experience power shifting the 6, but I double clutch my AT5 all the time.:p
    Seriously can you describe exactly what you mean by power shifting it. Some people don't understand what power shifting is defined as.
  6. May 16, 2011 at 6:39 PM
    Sandhopper
    Sandhopper Well-Known Member
    I think he is refering to slip shifting... Yes I do but most folks on hear frown upon slip shifting their Tacos. Mine actually shifts nice and smooth.
  7. May 16, 2011 at 6:58 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Power shifting is, leaving the gas peddle on the floor(bouncing off rev limiter) while shifting between gears. At least that's what everyone I have ever known calls it.
    If thats what you are referring to, I would highly recommend you don't. Most stick vehicles can't tolerate that for long. I know it will eventually blow the clutch in a stock BMW M3.
    If your talking about floating the gears (like a 18 wheeler), I would like to know the answer to that too. I imagine it can't be good for the synchros though, unless you can time it perfect every time.
  8. May 16, 2011 at 7:15 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    Wait how is double clutching bad?
  9. May 16, 2011 at 7:25 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    If this is what your talking about, as long as your good at it, sure why not. Although the only real benefit you get is not having to dump on your clutch at low speeds up hill.
    I wouldn't do this with any car or truck
  10. May 16, 2011 at 8:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I wouldn't do either of these with mine. The six speed is not the right trans to abuse. Has a reputation for being less than bulletproof and expensive to fix.
  11. May 16, 2011 at 9:14 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    i do it in the higher gears. 1-2 and 2-3 is pretty tough with this truck though. anything after is actually really nice and easy and smooth.
  12. May 17, 2011 at 3:00 AM
    colton1219
    Arizona
    SR5
    Powershifting or double clutching is definately not what I meant . Floating the gears or slip shifting is what I meant to say I. It just seems like I can ease it around much better and do it without really getting above 2500 rpms real easy? I just dont know about doing any damage to the throwout bearing or anything else thanks .
  13. May 17, 2011 at 5:11 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I thought power shifting was synonymous with slip shifting. So, power shifting, I would say, is bad. Slip shifting is good.
    Who the f thinks that running up to the rev limiter is a good idea anyway?
  14. May 17, 2011 at 6:38 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Whats next a spoiler on the tailgate lip?
  15. May 17, 2011 at 10:08 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    ^ holly shit, you are almost redlining it:eek:
  16. May 17, 2011 at 12:07 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
  17. May 17, 2011 at 12:51 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    you dont have to be going balls to the wall to powershift. its just shifting without using the clutch. though the video is what you would do if going as fast as possible =)
  18. May 17, 2011 at 6:07 PM
    Sandhopper
    If you are not forcing it through the gears you are not hurting anything. If you are jamming the gears you are going to break something quickly. If I want to shift fast I use the clutch... If I am not in a hurry, I will slip shift from 2nd on. Just accelerate, let off and slip into the next gear and accelerate again. My taco shifts real smooth that way.
