Power steering belt tensioner assembly bolt p/n 44350-34010
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tedocker, Nov 14, 2019.
  1. Nov 14, 2019 at 9:43 PM
    Tedocker
    Tedocker [OP] New Member
    Terry
    2000 Toyota Tacoma Prerunner Biege 2.7
  2. Nov 15, 2019 at 1:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    A picture would be a great help!
    Did you get the broken bolt out??
    Most likely either M10x1.25 or M8x1.25 guess at the length
  3. Nov 15, 2019 at 1:39 PM
    Tedocker
    Terry
    Here is a picture. I was able to get the bolt out. Unfortunately with out thinking I threw the broken bolt away when i picked up a supposedly part that fit from the dealer which didnt fit.
  4. Nov 16, 2019 at 6:04 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The long bolt that adjusts tension ??
    I have some I need to measure to be sure but M8x1.25 measure the overall length for length.
    It needs to be threaded the whole length .
    If you can`t find any you could make one with M8 x1.25 all thread and weld on a nut or epoxy .
  5. Nov 16, 2019 at 8:12 AM
    Tedocker
    Terry
    Thanks!
  6. Nov 16, 2019 at 8:13 AM
    Tedocker
    Terry
    Yes it is the long bolt. If you can provide the exact size that would be great.
  7. Nov 17, 2019 at 7:51 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It looks to be 80mm long.
    About the only thing I can have a fully threaded bolt of that size for
  8. Nov 24, 2019 at 4:10 PM
    Jaunty_Haul
    Jaunty_Haul New Member
    1998 Tacoma 5spd 4x4
