Power Steering Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by nick96, Nov 6, 2009.
  1. Nov 6, 2009 at 10:25 AM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    K&N Air Filter Window tint to match rear windows
    So I changed my starter out last weekend, pulled my power steering line at the front axle so I could get the damn thing pulled out. All the fluid did end up draining out.
    I did drive it without power steering fluid for about 25 miles. Just added power steering fluid and now in has the power steering "whine".
    Did I just screw up my pump by driving without fluid or is that noise the fluid working itself through the system? I'm hoping it's the latter, but I'm not holding my breath.
    Thanks.
  2. Nov 6, 2009 at 10:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, you just fucked the pump.
  3. Nov 6, 2009 at 10:32 AM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    That's great.
    So, this is something I can do or a shop?
  4. Nov 6, 2009 at 10:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    To replace it? Yeah, you can do it. It's just a couple bolts and the belt.
    FYI - Next time disconnect the belt if you have to run the truck with no powersteering fluid.
  5. Nov 6, 2009 at 10:40 AM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    Thanks for the info
  6. Nov 6, 2009 at 11:16 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Hopefully you didn't send metal into the Rack. when you change the pump make sure you flush the system really well.
  7. Nov 6, 2009 at 11:24 AM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    And if I did.......:confused:
  8. Nov 6, 2009 at 11:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ask redz..............:devil:
  9. Nov 6, 2009 at 11:55 AM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    Okay....PM sent!
  10. Nov 6, 2009 at 12:00 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i have a question too
    can you fuck the pump if you put too much power steering fluid in it ?
  11. Nov 6, 2009 at 12:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    Nope, it might leak out the top though.
  12. Nov 6, 2009 at 12:06 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    would another symptom be it only halfway works?
  13. Nov 6, 2009 at 12:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    Halfway worked? Whatcha mean?
  14. Nov 6, 2009 at 12:07 PM
    PrezidentRedz
    Redz
    Owings, MD
    not really but it will blow the seal on the cap. then Air can get it.
    Nick. when you install the new pump get a few bottles of ATF. those pumps dont use Power steering Fluid.
    1-Install the new pump, clean the resovor and install the pulley.
    2- Only install the High Pressure line.
    3. Plug the hole coming out of the res. and take the return hose and put in a bucket.
    4- Fill the res, and have some one turn over the motor as you keep pouring in new fluid, do not let it get to low....
    also they need to turn the wheel lock to lock to clear up the rack.
    then once you start seeing new fresh fluid coming out of the return hose. put the hose back on a res and top off the fluid.
    Then you should be good.
  15. Nov 6, 2009 at 12:10 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    like some times it works and sometimes it dosent
    you kinda have to rev the motor to get it to work
    and when it dose work its not like it should
  16. Nov 6, 2009 at 12:33 PM
    PrezidentRedz
    Redz
    Owings, MD
    The belt could be loose? does it squeal when you turn the wheel @ idle>?
  17. Nov 6, 2009 at 12:52 PM
    nick96
    nick96 [OP] Member
    Nick
    Portland
    1996 SR5 V6 4x4 AT
    Thanks. I will give it a go and let ya know how it goes!
  18. Nov 6, 2009 at 12:53 PM
    PrezidentRedz
    Redz
    Owings, MD
    yeah man just make sure to not let the pump run Dry ever. that is the worst possible..;)
  19. Nov 6, 2009 at 1:36 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    belts not loose
  20. Nov 6, 2009 at 1:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe your just weak? :p
