Power Steering Hoses
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RayGunSlayer, Aug 24, 2017.
  1. Aug 24, 2017 at 12:37 PM
    RayGunSlayer
    RayGunSlayer [OP] Active Member
    2005 Toyota Tacoma 4x4 4.0l V6
    I just recently bought a lifted 2005 toyota tacoma that use to go offroad. It has hydraulic steering on it right now and I'm about to change it back to power steering. One of the rubber hoses is cracked on the end and is leaking a little. I know one is the return hose and the other i the pressure hose coming from the bottom of the reservoir. What is the size of the hose that i need to buy to replace that hose. I looked to see if toyota websites sold that one specific hose like they do the return hose but they don't. They only sell it with the pressure line assembly and I really don't want to have to buy the hole pressure line assembly because the rest of it is fine.
  2. Aug 24, 2017 at 12:39 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Hydraulic steering is power steering
    jpereira2 likes this.
  3. Aug 24, 2017 at 12:49 PM
    RayGunSlayer
    Sorry it has hydraulic assisted steering. It's not the same. Hydraulic steering is better for offroad and has a little more play in it. The hydraulic has to build up pressure to turn. Power steering is instantaneous.
  4. Aug 24, 2017 at 12:53 PM
    Bebop
    Nick
    I think some pics of this steering setup are required
  5. Aug 24, 2017 at 1:13 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  6. Aug 24, 2017 at 1:13 PM
    RayGunSlayer
    I will later once I get the chance. My thing is are the two hoses coming out of the power steering reservoir the same or different hoses?
  7. Aug 24, 2017 at 1:14 PM
    RayGunSlayer
    I have found the same on ebay as well but i am just curious about the rubber hose since that was the only part wrong
  8. Aug 24, 2017 at 1:34 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    One is a pressure line; the other is a return line - fluid coming back into the power steering unit.
  9. Aug 24, 2017 at 1:58 PM
    knottyrope
    Knotty
    Bahstun
    need to get transmission fluid rated lines, regular rubber wont cut it
