Power Steering Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota14, Feb 11, 2012.
  1. Feb 11, 2012 at 5:30 PM
    yota14
    yota14 [OP] Well-Known Member
    Nathan
    Concord, North Carolina
    1996.5 Tacoma 4wd 6cyl 5spd
    TRD SuperCharger 6in TrailMaster Diff Drop 3in BLift Flow Master Exhaust Sony Explod Radio Pioneer Speakers Rear & Front 2 JL Audio 10" Subs Apline Amp Toolbox Westin Step Bars Vent Visors
    Hey yall my truck is making a pretty bad whine or hum when I start it up. If I let the truck warm up, then it will go away once its is warm. Tonight I just started it up and took off and turning out of the driveway the whining had a variation in sound.
    Any ideas on what to do to fix it?
  2. Feb 11, 2012 at 5:33 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    How's your fluid level look?
  3. Feb 11, 2012 at 5:46 PM
    yota14
    Nathan
    Just checked it man, its bout dang perfect
  4. Feb 11, 2012 at 5:48 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i have the same problem, and i just put a new ps pump on, im starting to think its the rack and pinion, mine leaks like a mofo
    edit: it leaks right out of the input shaft, right beneath the dust boot
  5. Feb 11, 2012 at 6:28 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    A common issue is the screen at the bottom of the reservoir. It gets plugged up and although there is fluid, it cannot flow causing the whine. I pumped out the reservoir and sucked the screen clean with a shop vac. Then refilled the reservoir and done.
    I read around that some guys just take a screw driver and punch a hole through the screen too. They hadnt experienced any problems and many vehicles dont even have such a screen.
  6. Feb 11, 2012 at 11:11 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    check your PS belt and idler pully. My idler pully was bad and it caused the PS system to hum/whine bad when turning. Replaced the pully and tightened the belt and it went away.
  7. Feb 12, 2012 at 5:10 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    i am gonna try this, thanks for the help, can the rack and pinion whine like a ps pump if it is not working correctly
  8. Feb 12, 2012 at 5:27 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    I have the same problem, Im going to give this a shot also.
  9. Feb 12, 2012 at 6:54 PM
    TacoMX
    Jonathan
    Deltona, Florida
    didn't someone recently post a thread about cleaning that screen? I have my high pressure hoses off because I am doing my R&P, so its drained...might as well do it while i have to apart.
  10. Feb 12, 2012 at 6:55 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I dunno, but I have posted this possible fix in at least 3 threads. haha
  11. Feb 12, 2012 at 7:10 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I had the same issue which later led to bearings destroyed in the pump, replaced pump, viola.
  12. Jun 6, 2013 at 8:50 AM
    trijetoh
    trijetoh New Member
    2001 Toyota Tacoma V6 4X4
    Hey, this worked for me. I got my wet-vac and adapted the end to a 5/8 inch tube and sucked out the bottom. Added new fluid and viola, no noise.
