Power Steering problems (whining pump)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Herk-A-Lees, Oct 14, 2009.
  1. Oct 14, 2009 at 2:28 PM
    Herk-A-Lees
    Herk-A-Lees [OP] Member
    SweetHomeAlabama
    95 4x4 single
    I lost power steering in my 1995 2.7L Tacoma about 3 days ago. I replaced the pump and had power steering restored, however, it made a real loud whining noise when I turned the wheel. Then, I lost power steering again.
    I just replaced the pump a second time and I have the whining problem again. My check engine light came on as well (not sure if the two are connected). Does anyone know what could be going on with my taco? :confused:
  2. Oct 14, 2009 at 4:43 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have always had them whine when they dont have enough fluid in it. Maybe you are leaking somewhere and letting it run dry and its burning it up IDK
  3. Oct 14, 2009 at 5:20 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    When it makes any noise like that your low on fluid or out, your best bet is to park your truck on a dry flat piece of ground to see the general area of the leak then find it and patch it. Or if there isn't a leak just go to a store and buy the correct fluid.
  4. Oct 14, 2009 at 5:20 PM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    Well, I can't find any leaks and the fluid level remains the same in the resevoir. I've had a couple of people look at it and neither has a clue what is wrong. I figured at least someone on here has had the same problem.
    This is a very frustrating problem. I wish I knew how to upload audio/video to this site.
  5. Oct 14, 2009 at 5:27 PM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    Could it be the type of fluid that I put in it? I thought power-steering fluid was power steering fluid.
    There is some sediment at the bottom of the resevoir. Could that have something to do with it?
    Also, I put some of that Lucas Oil- power steering leak stopper stuff in there before all these pumps started breaking. Could that be the cause?
  6. Oct 14, 2009 at 5:30 PM
    Andyd103
    Andrew
    New Hampshire
    For the most part fluid is fluid but they made different types, and yes that sediment is probably the cause for the whining its its getting sucked through the pump
  7. Oct 14, 2009 at 5:34 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Did you prime/bleed the hell out of it each time you installed it new?
  8. Oct 14, 2009 at 5:43 PM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    No, the guy at the auto parts store said I wouldn't need to bleed it. How would you bleed or prime it?
  9. Oct 14, 2009 at 5:45 PM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    There is a screen at the bottom where the sediment collects. I tried my best to get most of it out but there was still some in the bottom. I'm not sure how it would get down in the hoses.
  10. Oct 14, 2009 at 9:39 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    try draining and replacing all fluid (Flushing System). It helped with mine while I was waiting to get the new one in. I only replaced because the old one was so far gone.
    Fluid should be clear, not yellow or off colored. Also if it is foaming it is no good.
  11. Oct 14, 2009 at 9:51 PM
    texasbowhunter
    texasbowhunter Third Coast
    Texas Gulf Coast
    04 Double Cab 4x4 TRD
    Tinted Windows, Moto Metal 955's, Cooper 305/70/16 STT's, Deckplate Mod.,AFE Pro Dry, Toytec Coilovers, 2" AAL, Diff. Drop, Bilstein 5100's On the Corners, Alpine 10" Sub, Alpine 305 Head, Polk Mids
    Mine was making noise but it turned out that it was just low on fluid. How long did the second pump last before it went out?
  12. Oct 14, 2009 at 10:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you use ATF? I'm pretty sure the 1st gen trucks used ATF in the steering system.
    Do some research about the rack itself. Some 1st gen guys have had to replaced their steering racks.
  13. Oct 15, 2009 at 6:04 AM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    How do you drain? Or I guess the better question is where do you drain from? Other than the resevoir and the hoses, I don't know where the fluid could be drained from.
  14. Oct 15, 2009 at 6:05 AM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    2 days or about 40 miles.
  15. Oct 15, 2009 at 6:09 AM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    This scares me a little. The fluid that came out was a dark red/purple. The fluid I put in was rather clear.
    Unfortunately, I wouldn't know were to find the steering rack, much less replace one.:eek:
    After doing some more research, I believe the the system needs to be thoroughly flushed. I wanna pour new fluid in until the fluid coming out the return hose is the same color. Does anyone know where I could find a tutorial on how to do that? For example, I don't even know where the return hose is nor how to pump it out. I'm not much of a mechanic.
  16. Oct 15, 2009 at 9:27 AM
    Janster
    Jandy
    Lancaster, PA
    My husband and I flushed ours many years ago...
    We bought a couple quarts of cheap ATF (for flushing with) and then finished off with Mobile 1 ATF. You'll probably want someone else there to help you if you plan on doing a flush.
    Good Luck!!
    Here's a flushing method I found ...
    http://www.tacomaterritory.com/forum/showthread.php?t=30489&highlight=flush
  17. Oct 15, 2009 at 12:05 PM
    Andyd103
    Andrew
    New Hampshire
    yeah i've had to replace my rack, the pistons were leaking
  18. Oct 15, 2009 at 12:15 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    mine did the same thing, i replaced the pump and unscrewed the lines from the rack and let it all drain. all of the fluid was dark red and smelled burnt. make damn sure if you do unscrew them to put them on right and now to cross thread them. They are a PITA, but it fixed mine.
  19. Oct 15, 2009 at 1:42 PM
    Herk-A-Lees
    SweetHomeAlabama
    95 4x4 single
    Thanks for the help, everyone. I fixed it. It was the dang resevoir the whole time. The screen at the bottom had become covered with sediment. I tried cleaning the screen but ended up tearing it. So, I just removed it. Never had to flush the lines. Runs great now with no noise. I'm a happy man.:cool:
  20. Oct 15, 2009 at 3:54 PM
    Janster
    Jandy
    Lancaster, PA
    Very cool... & good to hear!!
    Might wanna look for another screen to put back in there sometime. Afterall - it's supposed to filter the sediment and prevent it from flowing through the system.
    MainerDave19995VZ likes this.
