Power Steering Pump, buy new or rebuild?
Discussion in '4Runners' started by mytoy04, Apr 5, 2013.
  1. Apr 5, 2013 at 4:50 AM
    mytoy04
    mytoy04 [OP] Well-Known Member
    Tim
    Liberty, MO
    99 4Runner 4cyl 5sp 4x4
    Can someone tell me if a seal kit will fix a noisey power steering pump? Last night I flushed the fluid hoping that would help but no change. The pump doesn't leak and appears to work fine. No steering issues at all, just very noisey. I'm debating on taking it apart and doing a seal kit or should I just buy a rebuilt one for over $100.
    The 4runner is a 2.7 4cyl 5sp 4x4 with 130k miles.
    Thanks
    Tim
  2. Apr 19, 2013 at 7:56 AM
    mytoy04
    Tim
    Liberty, MO
    Wow, two weeks and not one thought? I guess I'll just discuss this with myself. So my research has lead me to believe that maybe the screen is clogged up and not allowing the proper fluid to flow through the pump. I've located a used psp and will probably pull the reservoir clean it the best I can and reinstall. If that doesn't change anything then I'll rebuild it and have a back up if something goes south. I'll report back with results for those who are having the same issue. Kinda hoping pulling the reservoir and cleaning will solve the problem.
    Tim
  3. Jun 6, 2015 at 9:25 AM
    Ran s Taco Stand
    Ran s Taco Stand Member
    Randy
    Kings Ferry, FL
    06 Prerunner SR5
    '06 Prerunner 2wd Access Cab 190099 miles and counting!! Stock, but still Bad-Ass!! '95 Tacoma 5speed 2wd 348,000 miles '98 4Runner SR5 Auto 2wd 329,000 miles '88 4Runner SR5 Auto 4wd 2??,??? miles on blocks for now
    Hey Tim, I'm having a noise coming from my PS pump as well...what was the result on the rebuild? Did it cure the noise? Did your kit include bearings? If so what brand and part number?
  4. Jun 6, 2015 at 9:27 AM
    Ran s Taco Stand
    Randy
    Kings Ferry, FL
    06 Prerunner SR5
    It only took 2 years and 2 months for me to find your therad...i hope u see my post and respond :popcorn:
  5. Jun 6, 2015 at 3:55 PM
    mytoy04
    Tim
    Liberty, MO
    Hey Randy,
    I wish I could tell you about the pump rebuild but I never did it. The used pump I put on worked and has been working good so I never got around to rebuilding it. Sorry, curious how yours comes out tho. Good luck!
  6. Jun 7, 2015 at 1:03 PM
    Ran s Taco Stand
    Randy
    Kings Ferry, FL
    06 Prerunner SR5
    Well upon my poor original diagnosis...I found out the hard way last night it ended up being my alternator...although I think I need a new PS pump too as well as new idler pulleys and possibly soon a new water pump or fan clutch...it's a tiny bit wobbly. I have 247,000 miles so I'm due...lol. i have a few noises coming out from under the hood, but still mechanically sound! thank you for responding I have some work to do I guess
  7. Oct 28, 2022 at 7:50 AM
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    I know this thread took a turn from the original inquiry, but I am still interested in people's preference for either a new or remanufactured PS pump. Mine seized. I replaced it with a reman'ed pump from Endurance. I bought it from AutoZone. While it was listed as Endurance, the box said TrueGrade. I had never heard of either of these manufacturers.
    The reman'ed pump I installed leaks at the seam where the two halves are joined on the underside of the pump. So, I now have to replace it again. I am trying to decide if it is better to go with a reman'ed pump or a new one that does not use OE core.
  8. Oct 28, 2022 at 6:59 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Just get a new OEM and not have to worry about it for another 200k
