Power Steering Pump issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by hondakubota, Nov 6, 2009.
  1. Nov 6, 2009 at 1:38 PM
    hondakubota
    hondakubota [OP] New Member
    Michigan
    2004 Tacoma
    2004 Tacoma 2.7L 4wd blew all the power steering fluid near the front of the engine and on the hood. (See photos). Pump made noise after fluid came out. Did not continue to drive the vehicle. Put fluid in pump and everything appears to be OK. Biggest problem is I cant tell where the fluid came out and it is not currently leaking. Should I just go ahead and replace the pump? What about the hoses? Any ideas on how to figure out exactly where the oil came out? Anyone had this issue?
  2. Nov 6, 2009 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Where is the fluid comming out?
  3. Nov 6, 2009 at 1:45 PM
    hondakubota
    Michigan
    2004 Tacoma
    Thats the magic question. It all blew out at once. I refilled the pump with fluid and now it does not leak. Since the oil is everywhere cant tell where it came from.
  4. Nov 6, 2009 at 1:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wow...Thats strange. And everything is fine now??
  5. Nov 6, 2009 at 1:51 PM
    hondakubota
    Michigan
    2004 Tacoma
    So far but my concern is that its just a matter of time before it occurs again. Given that I am wondering if I should just go ahead and install a new pump?
  6. Nov 6, 2009 at 1:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would keep an eye on it. It may have just blown the top loose and leaked out like that.
  7. Nov 6, 2009 at 2:00 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Get some simple green and clean that motor. then after its dry. Drive around for a little while and then look for leaks.
  8. Nov 6, 2009 at 2:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo!
  9. Nov 8, 2009 at 6:10 PM
    hondakubota
    Michigan
    2004 Tacoma
    All cleaned up and drove the truck last night and today. No signs of leaks.
  10. Nov 8, 2009 at 6:32 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    mine just did the same thing about two weeks ago. fluid all over the hood and the whole pump reservoir was coated. No issues though. I think i may have overfilled it and it had to go somewhere.
  11. Nov 11, 2018 at 3:19 PM
    Navydude3
    Navydude3 Active Member
    2001 tacoma v6 sr5 2wd
    Mines doing the same thing, but it’s the 3.4 and it’s gotten bigger over the course of about a month, what do you guys think I should do( I haves refilled the fluid yet but I intend on doing so soon)
