Power Steering Rack & Pinion "shot"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stripperclip, Jul 12, 2012.
  1. Jul 12, 2012 at 12:23 PM
    Stripperclip
    Stripperclip [OP] Well-Known Member
    Colorado Springs
    2016 Tundra SR5 TRD ~ White
    And for my first post....
    A local shop says my rack & Pinion is "shot" and they were not able to complete my alignment. I got a quote for a Napa rack & pinion for a little more than $500 plus bushings, labor, etc. Isn't there a Core price that should be adjusted when they turn in my old rack & pinion? Did they just fail to mention this?
    Anyone know a good shop in Colorado Springs?
    Thanks in advance.
  2. Jul 12, 2012 at 4:17 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    yes there is usually a core charge, look it up on napaonline.com
  3. Jul 15, 2012 at 1:19 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    How many miles are on your truck?
  4. Jul 15, 2012 at 1:42 PM
    BamaToy1997
    Bill
    Navarre, FL
    It depends on if you are getting a new or a remanufactured one. When I buy a new part for a customer, be it a rack and pinion, or an alternator, or whatever, I don't have a core charge. That being said, when I quote a repair to a customer, I don't mention the core charge, because it does not affect the amount I bill my customer. I base my markup only on the cost of the part, never the core charge, as I get the core charge back.
  5. Jul 15, 2012 at 2:14 PM
    x2468
    how do you know they aren't just telling you it's shot to make a buck off you.
  6. Jul 15, 2012 at 4:49 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ya cause the bushings go out on our steering racks a lot actually. You can get the bushings from Wheelers for like 20 bucks. Bitch to install but do able.
  7. Jul 16, 2012 at 8:30 AM
    Stripperclip
    Colorado Springs
    I have 219,000 miles on the truck so I'm guessing the rack & pinion is worn out. I get the shop marks up parts, my company does the same thing, but when I go to Napa's website and the most expensive rack & pinion is $282 and a $222 core price it just seems like I'm paying for the core and the shop gets the core credit when they turn it back in.
    My truck has been bomber proof. This is the first part I've had to replace because of failure besides breaks. I don't have a "favorite" shop since I haven't needed work. Any national chain shops I need to stay away from?
    Thanks for the help guys.
  8. Jul 16, 2012 at 10:31 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I had my rack and pinion replaced at Larry H Miller in CO Springs when I had my timing belt and water pump replaced. They seemed to have done a pretty good job, but it was about $1000 for just the rack and pinion! And I went with the cheaper remanufactured parts instead of toyota OEM replacement, which they said would save me around $200 I believe. I was going to change it myself, but with traveling for work and since it was already in the shop, I just had them do it.
  9. Jul 16, 2012 at 10:47 AM
    BamaToy1997
    Bill
    Navarre, FL
    Your repair shop should not be charging you for the core. that is considered poor business practice. It depends also on where they get their parts. Maybe you found a matching R&P at Napa, but the shop doesn't buy cheap napa parts, but uses a distributor with a higher quality, hence higher priced, unit. I try to find my customers the best deal I can, but I'm not going to call 40 different part suppliers to do this. I go with the suppliers that give me the best deal. (best deal as in good price for quality parts. I will pay more for quality parts)
    $500 for the parts, including bushings and labor is a good deal.
