Power windows for 1999 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulcleston, Mar 8, 2008.
  1. Mar 8, 2008 at 2:34 PM
    paulcleston
    paulcleston [OP] Active Member
    Does anyone know of a kit to install power mirrors on a 1999 Tacoma SR5 Extra Cab. I have looked on line for used parts and have been unable to find them. Also if there is another model that will interchange with these. Any help would be appreciated. When I started this thread I stated power windows by mistake. I really need power mirrors.
  2. Mar 8, 2008 at 7:03 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Pull the little triangle pannel on the inside against the window, and see if there is an unused harness with a plug there for the power mirrors. Then see if there is a harness plug behind the knockout where it is supposed to go (can't remember if the mirror controlls in a gen 1 were on the armrest or the dash)
    If the harnesses are there then is should be a matter of hitting up a junk yard for the power mirrors, and the switch and then connecting power at the fuse block, though realistically how often do you adjust your mirrors? It seems like alot of work even if it is possible.
  3. Mar 9, 2008 at 9:06 AM
    paulcleston
    Thanks for the reply. I will look and see if the connections are there. I have been told that Toyota wired all their trucks as if they would receive all attachments reguardless of how they were equipped.
    My wife sometimes used the pickup and the mirrors have to be adjusted. We are older and it is difficult for her to adjust the passenger side mirror. Thanks again. Paul
