Power wires for 2010 radio harness
Discussion in 'Audio & Video' started by prpnum1, Aug 22, 2011.
  1. Aug 22, 2011 at 12:21 PM
    prpnum1
    prpnum1 [OP] Member
    Derek
    Georgia
    Hey, I'm trying to install my new head unit and can't seem to find a radio wiring diagram anywhere. Can anybody tell me which wire on the 4 plugs are 12v, switched 12v, and ground please. Thanks.
  2. Aug 22, 2011 at 1:02 PM
    prpnum1
    prpnum1 [OP] Member
    Derek
    Georgia
    Nobody knows??
  3. Aug 22, 2011 at 5:15 PM
    pinktaco808
    pinktaco808 Hot Steppa
  4. Aug 22, 2011 at 5:47 PM
    jsucraig
    jsucraig Well-Known Member
    Craig
    Lynchburg, Virginia
    2013 Tacoma TRD Off-Road Double Cab
    Mudflaps removed, MESO LED Interior lights, 886 Fog Lamps for Reverse Halogens, Redline Tuning Hood Struts, Garmin Dashcam 20, 17X8 Chrome Helo HE791 MAXX Wheels, Cooper Discoverer AT3 265/70R17, JBL Speakers, JL Sub, and Alpine & Memphis Amps, mattgecko LED Bed Light & Under Hood Kit, Truxedo Low Pro QT Tonneau Cover, OEM Bed Mat
    I just installed a Pioneer AVIC-X930BT using Metra Wiring Harness Part# 70-1761 and the Pioneer supplied aftermarket wiring harness for the unit. The Metra Harness has the color codes on the packaging after soldering, or splicing, all of the connections to the Pioneer supplied harness you just plug the factory harness into one side and the Head Unit side into the new aftermarket head unit. I didn't worry about factory wiring colors.
  5. Aug 22, 2011 at 6:01 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    ^^^ What he said.
    The TTORA site has some diagrams online that will work. IIRC, the plug with the front speaker wires also has a gray wire (switched), a blue/yellow wire (12V) and a brown wire (ground). With a VOM these should be easy to verify.
