PowerTrays - Mounting Platforms for Electrical Accessories and More!
Discussion in 'PowerTrays' started by Mr.PowerTrays, Nov 3, 2017.
  1. Nov 3, 2017 at 5:02 PM
    Mr.PowerTrays
    Mr.PowerTrays [OP] Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    Hello Tacoma World,
    My name is Maverick, Tacoma owner turned entrepreneur. I recently started to design and manufacture mounting platforms that accommodate the industries most popular electrical accessories.
    • Specifically designed for the Toyota Tacoma, PowerTrays are water-jet cut out of 1/8" Aluminum.
    • Instead of the traditional 90° bend offered by others, PowerTrays are bent 100°. This additional 10° allows the tray to match the angle of the inner fender and alleviates the stress caused by an improper fit.
    • Most importantly, PowerTrays are aided by an additional support leg that secures the far side of the tray to the lower fender. By offering a 3rd mounting point, the PowerTray is able to achieve unparalleled stability.
    • These ship right to your front door with full color instructions and all mounting hardware needed for installation.
    Currently there are 4 configurations offered:
    • Universal – Blank slab for you to create your masterpiece.
    • Switch Pros – Pre-drilled and slotted for a Switchh Pros, Terminal block, bussbar and fuse box
    • sPOD SE – drilled and slotted for an sPOD (6 switch, 8 switch, SE)
    • sPOD Bantam – Being released in Febuary.
    More trays are in the works! I will be releasing additional options for mounting the Blue Sea and Cooper Bussman line of products soon.
    In honor of being granted official vender status, by the great and all powerful @tcBob, I am offering a special to all my fellow TacomaWorld members. At anytime use code “TWPROUD” on my website for 10% off your purchase of any Tacoma PowerTrays.
    www.powertrays.com
    Let me know what you think and also what you would like to see next!
    IMG_4615.jpg IMG_5049.JPG.jpg IMG_7126.jpg IMG_5558.jpg IMG_5553.jpg IMG_5557.jpg IMG_5317.jpg
  2. Nov 3, 2017 at 5:03 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
  3. Nov 3, 2017 at 5:03 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    Useful Information:
    Fuses and Circuit Breakers
    The main reason we run circuit breakers/ fuses is because if a positive battery cable is accidentally grounded, the rapid discharge of energy may/will cause a fire. Also it prevents the load from either drawing more current than it, or the cable, can handle. But most of us are aware of our energy consumption and properly fuse our accessories so the protection is more for the cable that gives power to the Switch Pro, than the Switch Pro itself.
    The most common cause of grounding a positive wire is usually user error... However, more serious cases happen all the time. We definitely put our trucks through their paces, and as a result the high vibration/abrasion battery cables are subject to can easily wear through the protective coatings on the cable over time. Worse yet, in the event of an accident a cable can get pinched and start a fire that way too.
    Circuit breakers are great for the user error scenario, because it only happens for a second and we can just reset it. But it's important that your circuit breaker be placed as close to the source (battery) as possible, otherwise you're leaving a stretch of the cable unprotected.
    I always recommend fusing your power cable directly at the source with a Marine Rated Battery Fuse. It's the best way to guarantee your safety because 100% of the cable will be protected if anything were to happen. Also it mounts directly on the battery terminal, so there's no need to have a separate mounting space allocated for it.
    But it is just a recommendation and not a requirement. I know plenty of people that just run a straight positive cable from the battery to the Switch Pro and that's up to you.
    Manuals and relocating the clutch fluid reservoir.
    Just pop the reservoir out of its bracket.
    Unbolt the factory bracket and attach it to the underside of the PowerTray by using the “clutch fluid reservoir relocation bracket”.
    Install the PowerTray like normal with the reservoir just pushed out of the way.
    Once everything is in place, just take the clutch fluid reservoir and clip it back into its original bracket.
    IMG_5773.jpg IMG_5779.jpg IMG_5777.jpg IMG_5789.jpg IMG_5791.jpg IMG_5793.jpg
  4. Nov 3, 2017 at 5:54 PM
    Coop68
    Coop68 Well-Known Member
    Coop
    Erie/Dacono, CO
    2014 TRD OR Magnetic Gray
    Method double standards 16" COOPER S/T MAXX 285/75/16 DEI clifford 2-way remote start with smart-start. Lift Kings with Dakar TC UCA extended brake lines Keyless POP-N-Lock tailgate lock,relentless tailgate reinforcement, Weather Tech Mats all around, pelfreybilt front bumper steel with middle hoop warn VR-8000s switch Pro lights coming soon see build thread
    Will be installing mine hopefully tomorrow!:thumbsup:
  5. Nov 3, 2017 at 6:10 PM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    I'll be hitting you up soon when I figure out if(or should I say when :laugh:) I'm gonna move to the Switch-Pro.
  6. Nov 3, 2017 at 7:09 PM
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
  7. Nov 3, 2017 at 8:16 PM
    Martyinco
    Martyinco Well-Known Member
    Subbed because @Coop68 threated to beat me up in the hallways
  8. Nov 3, 2017 at 8:32 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Congrats on the new venture! Looks great.
    lobsterbait likes this.
  9. Nov 3, 2017 at 9:29 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    haha he's all talk... unless you don't do what he tells you... :spy:
    Martyinco[QUOTED] likes this.
  10. Nov 3, 2017 at 9:30 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    Perfect! I'll expect pics :fistbump:
    Coop68[QUOTED] likes this.
  11. Nov 3, 2017 at 9:37 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    Another great option would be a mount for winch solenoids under the hood and also air compressor mounts too.
  12. Nov 3, 2017 at 9:38 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Congratulations on the new adventure! They look great!
    Mr.PowerTrays[OP] likes this.
  13. Nov 3, 2017 at 10:01 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    hey @gordi we're actually working on a compressor mount now and I like the idea of a solenoid mount too... I may have to think on that.
    Giffmann and gordi[QUOTED] like this.
  14. Nov 3, 2017 at 10:03 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    Thanks @mach1man001! I appreciate the support :hattip:
  15. Nov 4, 2017 at 8:56 AM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    CharlieCafe[QUOTED] likes this.
  16. Nov 4, 2017 at 9:26 AM
    CharlieCafe
    Charles
  17. Nov 4, 2017 at 6:05 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Just searching through vendors who recently posted and look at this! Just ordered a switch-pro and wasn't to satisfied with the mounting solutions I've seen.
    Ordered.
    Thanks for the discount!
  18. Nov 4, 2017 at 8:22 PM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    Haha nice! Must be fate :thumbsup:
    solscooter[QUOTED] likes this.
  19. Nov 5, 2017 at 8:31 AM
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    A little birdie told me that you can now set each switch to "trip" at a specific amperage instead of just 18/35 amps per switch. So if you have super small wire that gets pinched the switch pros has the ability to cut power (if set correctly) before the hole wire goes up in flames.
  20. Nov 5, 2017 at 8:35 AM
    DrFunker
    DrFunker Well-Known Member
    I really need one of these. :rolleyes:
