Pre-ignition on slight acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmatheny, Jul 22, 2008.
  1. Jul 22, 2008 at 5:11 PM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    I have started getting some mild pre-ignition under light acceleration. 6500 miles. Probably that shitty ethanol in the gas here! I put regular Exxon 87 octane.
    Anyone else noticed this??
  2. Jul 22, 2008 at 5:22 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Ya I have heard of complaints about pigging when using 87 octane little worse with the A/C on I tend to blend my gas I will switch back forth between the grades so it will never have just 87 octane in it.
  3. Jul 22, 2008 at 6:51 PM
    NHinAK
    NHinAK Active Member
    Anchorage
    08 Tundra TRD
    -Debadged
    I never noticed it stock, but I used premium. I did get it with the addition of the charger when the temps started to get warm. Cured the detonation with Sunoco 104 Unleaded.
    Try getting some premium and see how it does.
  4. Jul 23, 2008 at 7:22 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    104 - wish we had that kind of octane here! I'm sure premium would elminate it, but at $4.20/gal?!?!?
  5. Jul 23, 2008 at 7:24 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, try a little premium. you dont have to fill up with it, just do maybe half and half. you may even cure the pinging with some 89....worth a shot anyway.
  6. Jul 23, 2008 at 7:39 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I run premium on mine and I don't have any issues. When I would run regular, I got a little rough idling.
  7. Jul 23, 2008 at 7:40 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Does gas mileage go up with higher test gas?
  8. Jul 23, 2008 at 7:56 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
  9. Jul 23, 2008 at 8:02 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    How much is the increase, is it worth the higher price?
  10. Jul 23, 2008 at 8:21 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It was worth about 1 mpg. That's not why I run it though.
  11. Jul 23, 2008 at 8:45 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i'd say 1, maybe a bit more, but honestly....i run mid grade and premium cause it keeps the fuel system cleaner, and the truck runs better to me on it.......i can tell a decent difference between regular and mid/premium. keeping the fuel injectors clean will result in better mileage........another reason i run it. plus, if you do the math........its really only a few $ difference if you fill up with 87 versus 89/91/93......not too much.
  12. Jul 23, 2008 at 2:04 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    One grade of gas keeping the system cleaner over another is a myth - all grades have the same cleaning additives. Just the octane differs.
    Run a bottle of Guaranteed to Pass throuh it every 6 months if you are worried about buildups.
  13. Jul 23, 2008 at 3:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah, i run a bottle of techron thru the tank at every oil change........never had a problem.
  14. Jul 23, 2008 at 8:06 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
  15. Jul 23, 2008 at 10:51 PM
    BeefTaco
    I mainly use Chevron gas and used to add a bottle every once in while till I found out that all grades of Chevron gas already has techron in it.
  16. Jul 23, 2008 at 11:07 PM
    the new guy 05
    the new guy 05 Member
    mesa town
    o8 single cab tacoma preruner
    i have an 08 taco with a 2.7L 5spd, have just under 3k on it and i have never put anything less then 91 in it, would u guys say its pointles?
  17. Jul 24, 2008 at 5:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, the 4 banger does well on regular, but its up to you really. and its only a sifference of a few bucks really on a fill up.....well used to be anyway. just run what you feel comfortable with.:)
  18. Jul 24, 2008 at 5:23 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i run sunoco all the time, but i always like the peace of mind of the techron with every oil change.
  19. Jul 24, 2008 at 6:55 AM
    StompinStu
    StompinStu Active Member
    Baton Rouge, LA
    06 PreRunner Access Cab I4 5 speed
    A lot of the problems you mention and others mentioned below is because of the crappy ethanol blends. There are a few indy stations near me that are selling, and touting, their 100% gas. I fueled there a few times, with 87 octane, and there was a noticable increase in performance and economy.
    Goddamn federal regulations are only doing two things, wasting gas, and reducing engine life.
  20. Jul 24, 2008 at 7:01 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Well, got me there! However, I will stand by my statement about Guaranteed to Pass - I used a single bottle in a 93 Nissan Altima with 160,000 miles on it. Shortly after, I had to pull the injector bank for another reason, and the injectors looked brand new - absolutely pristine!
    OH, and I shouldn't have injector buildup after only 6500 miles.
