pre runner 4x4???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Endo-4x4, Feb 21, 2017.
  1. Feb 21, 2017 at 2:00 PM
    Endo-4x4
    Endo-4x4 [OP] Well-Known Member
    Definitely will.
  2. Feb 21, 2017 at 2:06 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Get the VIN and check it with your favorite dealer... maybe CarFax or there is a guy on here that will run a check for you. I'm sure someone here has a link to his thread.
  3. Feb 21, 2017 at 2:10 PM
    Endo-4x4
    will do, Clevsix. I think vehiclehistory.com does it as well
  4. Feb 21, 2017 at 2:11 PM
    Endo-4x4
    Update: pics confirm j-shifter and a clean ass interior
  5. Feb 21, 2017 at 2:12 PM
    Endo-4x4
  6. Feb 21, 2017 at 2:14 PM
    Wulf
    Wulf no brain just damage
    Kira
    1789 28th St, Boulder, CO 80301
    rock raisin
    Is the salad included? :p
    eon_blue likes this.
  7. Feb 21, 2017 at 2:17 PM
    eon_blue
    eon_blue Most Improved Member
    FYI that's not a J-shifter, that's the electronic 4hi shifter (I have the same one). The J-shifter is fully manual, without a 'push button' to activate 4hi. Not a big deal, the j-shifter seems to be more sought after around here though. It's not as common in the later model first gens. Clean looking interior though
  8. Feb 21, 2017 at 2:18 PM
    Endo-4x4
    Oh, interesting... I guess I associated j-shifter w/ any 4-lo/hi stick. Thanks for the knowledge
  9. Feb 21, 2017 at 2:30 PM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    What would make the J shifter more sought after? I know the push button was a couple hundred bucks extra from the factory. I've had a tacoma with and without it and the push button is pretty nice. End of the day though they both do the same thing. I guess maybe the push button could break? haven't heard that being a problem though.
    eon_blue[QUOTED] likes this.
  10. Feb 21, 2017 at 2:32 PM
    ClevSix
    IL/IA
    most prefer the J Shift because it is one less electric thing to fail.
  11. Feb 21, 2017 at 2:33 PM
    eon_blue
    That's pretty much it, there's one less thing to worry about with the j-shifter. The solenoid on the push button can fail and leave you without the ability to go into 4wd, easy fix but could be a big problem if you're out and about and need to use it. Not a common occurrence but a possibility.
    Same reason why some people still prefer manual hubs, even though they're much less convenient
  12. Feb 21, 2017 at 2:47 PM
    BiNiaRiS
    Portland, OR
    Understandable but at least it seems like the push button failing is very rare. Was just reading up on this though and the push button 4wd gives you a twin stick (2wd lo) mod that is super easy. Switch into lo and it's 2lo, press the button and its 4lo. Gonna have to do that to mine today since it's literally a 1min mod, haha.
    OP, if you pick up this truck, here's the "write up" aka unplug this thing and you're done.
    https://www.tacomaworld.com/threads/2-lo-mod.248180/
  13. Feb 21, 2017 at 3:12 PM
    Endo-4x4
    wuuuuttt :boom:
  14. Feb 21, 2017 at 3:49 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
  15. Feb 21, 2017 at 3:50 PM
    #35
    Endo-4x4
    awesome thank you! Guy is not available to show until Sat. so I will get vin by friday (if he hasn't sold it to his neighbor by then) and give your guy a shout.
