Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Dec 10, 2017 at 10:13 AM
    #1381
    bshammer0
    bshammer0 [OP] Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Can’t hurt to try. The subbies do sound amazing for sure but perhaps we’re just paying a premium for the plug n play-ability IDK! Let us know how it turns out - worse case the other tweeters will still be there and Crutchfield is great about returns
  2. Dec 10, 2017 at 12:37 PM
    #1382
    DeathsArrow
    DeathsArrow Well-Known Member
    One thing worth noting, the signal from the head unit goed through the tweeters and is passed to the front door speakers. You'll have to do some custom wiring which isn't that difficult, but I wanted to make you aware of it.
  3. Dec 10, 2017 at 2:21 PM
    #1383
    FLdub
    FLdub Well-Known Member
    SRQ FL
    2016 Black Tacoma TRD OR 4x4
    Thanks, ill most likely go with the Subaru tweeter out of ease of install. Mainly because im lazy and dont feel like messing with a mount and wiring. haha
    bshammer0[OP] likes this.
  4. Dec 10, 2017 at 6:30 PM
    #1384
    bshammer0
    Brandon
    Nashville, TN
    Super easy - follow that video and it will take you 10 mins per side and they will plug and play!
    shakerhood and DeathsArrow like this.
  5. Dec 10, 2017 at 10:30 PM
    #1385
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Just when I thought I was done Christmas shopping, I come across this thread :mad:. Well TW strikes again...Subaru tweeters purchased today :bananadance:
  6. Dec 11, 2017 at 7:32 AM
    #1386
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Going different route than front 6x9 and suburu tweets so gonna ditch them if anyone interested pm me. Been in car a month. Products are what op listed i decided to go components and amp.
  7. Dec 11, 2017 at 6:41 PM
    #1387
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
  8. Dec 15, 2017 at 12:29 PM
    #1388
    Disco
    Disco Well-Known Member
    Diego
    San Diego
    2018 TRD Offroad 4x4 DCSB Cement
    Ive had these speakers in my garage for a while and will be getting my truck in a couple weeks. I honestly don't know much about audio equipment. Will these 6.5 speakers work on the rear? It includes flat ribbon type tweeters, would I just leave those out?
  9. Dec 15, 2017 at 12:32 PM
    #1389
    RedEmpire
    RedEmpire Well-Known Member
    Southern Pines, NC
    2017 MGM Tacoma DCLB 4X4
    Those are components and if you use those tweeters you will have to do some extra wiring as they won't plug right into factory harness and if factory tweeter cable is not powered/working the door speakers won't work either. They would not sound good in the rear as they are designed to be used with those tweeters.
    Disco likes this.
  10. Dec 15, 2017 at 12:36 PM
    #1390
    Disco
    Diego
    San Diego
    Thanks. I'll just sell these off and use the cash to buy the right speakers for the Taco.
  11. Dec 15, 2017 at 12:39 PM
    #1391
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    6.5's will fit in the rear (assuming those don't have an insanely big mounting depth). As for the ribbon's...that would be a new one for me. I've only seen them in home theater setups, not in a vehicle (although I knew it was something that people have done).
    As for putting those in the rear, I'm not sure where you'd want to mount the ribbon's without some modification to the door itself. If you have any rear passengers, would not recommend using just the 6.5's without the tweeters tho. It will sound horrible to them because you are only using them as rear filler speakers at that point...
    You might be able to put this component up front without much issue/modification of the stock tweeter location. Of course, it all depends how big those tweeters are.
  12. Dec 15, 2017 at 12:45 PM
    #1392
    Disco
    Diego
    San Diego
    Thanks, is there a thread with some speaker recommendations and installation instructions somewhere?
  13. Dec 15, 2017 at 12:57 PM
    #1393
    ToyoDrew
    Texas
    Most people have been happy with the JBL speakers mentioned a lot in this thread. Beyond that, there is a lot of good info scattered throughout this thread that goes beyond just simple plug and play:
    https://www.tacomaworld.com/threads/2016-bbp-audio-build.430252/
    Most 6x9's or 6.5 speakers (components or coaxials) will fit our Tacos up front (only 6.5's in the back). You actually go slightly bigger up front if you can make the right adapter and the mounting depth isn't too deep. The biggest limiting factor is usually your budget. :)
    For installation instructions, the video that OEM+ made (specifically for the 3rd gen) is a great video. It has been posted and reposted all over this forum, so it should be an easy search...
  14. Dec 15, 2017 at 1:20 PM
    #1394
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    So I could install ONLY this and run an amp/sub? How does it sound using this? Doesn't have great reviews on Amazon.
  15. Dec 15, 2017 at 1:52 PM
    #1395
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    Go back and read the very first post in this thread
    Friedtacolover and bshammer0[OP] like this.
  16. Dec 16, 2017 at 5:07 AM
    #1396
    Friedtacolover
    Travis
    Ontario, Ca
    That works for a single (mono) amp yes. So just a subwoofer no speakers ran on it. If you want to run a lc7 or 5 channel amp to power speakers/sub you need to follow the directions here:
    Page 1 and 7. I just followed them and created this to run to my amp.
  17. Dec 16, 2017 at 8:56 AM
    #1397
    paunchy
    paunchy New Member
    2016 DCSB TRD Sport
    As if 70 pages of positive feedback wasn't enough, I'll pile on and report that I did the tweeters only. Wow! This is easily the best $100 I've spent on a car. I bought off Amazon because... Prime shipping.
    No hassles, and the whole thing took less than 30 minutes. Thanks TW!
  18. Dec 16, 2017 at 9:09 AM
    #1398
    DeathsArrow
    It sounds fine. It's not going to thump really hard but it fills in the low end and gives a little more oomph to the bass. If you've ever had a factory sub before, it's similar to that. I read the Amazon reviews before I bought it. The only thing that concerned me were the people that had failed units soon after use but who knows if they even wired it correctly.
  19. Dec 16, 2017 at 7:14 PM
    #1399
    Hamer460
    Hamer460 Active Member
    Henry
    2017 Silver SR5 2WD Double cab
    Just bought everything.
    Haven't had a decent stereo in 20 years.
    Thanks bshammer0 for posting
    bshammer0[OP] and Friedtacolover like this.
  20. Dec 16, 2017 at 7:53 PM
    #1400
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    One door done. Even with 1 door, it sounds way better.
