Prerunner >>> 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Oct 29, 2009.
  1. Oct 29, 2009 at 1:28 PM
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    hey all. posted this on TTORA and hope to get some inputs here as well.
    i've been doing ALOT of research on this topic (Prerunner >>> 4wd) and learning ALOT and still more to learn.
    well, another question......
    i have stock 4.10s in the rear. while wanting to try and get 4.10s in the front, is it okay for me to get 3.91s in the front and 4.10s in the rear???
    is it that much of a difference and will cause damage, since it's mainly for the snow and off-roading???
    the reason while i'm asking is because there is a killer deal here (locally) from a guy who just did the SAS on his rig and i'm getting mixed results from "searching". pretty much cut up his IFS, which is what i'm after.......everything......manual hubs and all.
    truck is a 2001 Taco Prerunner V6 auto.
    thanks.
  2. Oct 29, 2009 at 2:03 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Gears have to be the same front &rear.
  3. Oct 29, 2009 at 2:05 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    nope have to be the same
    but if i were you id still take the deal you can allways get diffrent gears
  4. Oct 29, 2009 at 2:21 PM
    El Taco
    STP MN
    well, like i said, i'm "learning" here.......
    if i were to get that deal (the entire manual hub IFS front) can i just simply swap those manual spindles and axles into an ADD diff with 4.10s???
  5. Oct 29, 2009 at 2:48 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i think so but im about 70% shure on that
  6. Oct 29, 2009 at 3:17 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    If the deale ris good and you can spend another #150 to $400 on the right gear, then you are golden.
    Talk with a shop that can install gears for you and see what the real cost is.
  7. Oct 30, 2009 at 5:19 PM
    El Taco
    STP MN
    posted this on TTORA as well.
    learning here still, question:
    can i "mix and match" the front diff and transfer case?
    example: can i use a "non-ADD" transfer case and bolt that to an "ADD" front diff? or do i have to go all ADD or non-ADD?
    i'm asking because there is a "non-ADD" i can get here locally. upon the "extensive" research i've been doing, the "non-ADD" front diffs are more desired. is this true too for the transfer cases?
    i'm assuming that if this is possible, then the setup would be like this:
    ADD front diff with "non-ADD" transfer case with manual hubs???
    thanks.
  8. Oct 31, 2009 at 8:13 AM
    El Taco
    STP MN
    anyone?
  9. Oct 31, 2009 at 9:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    #1 - you must have the same gears front & rear. Don't skimp on something like that or else it'll bite you in the ass later.
    Not sure what you mean by a NON ADD transfer case?
    Are you referring to the differences between manual & electronic engagement of the t-case?
    I would say, NO...you can't have a manually engaged t-case with an ADD front diff or vic-versa unless you electronically set it up properly.
    For ease of installation & less complications - you're better off going with everything MANUALLY. A manually (non ADD) engaged t-case with a standard t-case (NON-ADD) and manual hubs.
  10. Oct 31, 2009 at 9:47 AM
    El Taco
    STP MN
    yes, i meant the manual engagement and not the electronic engaged t-case.
    hmmmm......so i can't do this then huh?
    manually engaged t-case >>> mated to an ADD front diff >>> with front manual hub/knuckles???
    i ask this because the ADD front diffs are more common. i have my hands on a "non-ADD" aka manual engagement t-case.
    just need to know if this works? thanks all.
  11. Nov 1, 2009 at 8:44 AM
    Janster
    Jandy
    Lancaster, PA
    Don't quote me on any of that because I don't know for sure.
    On my 96 tacoma - I had a manually engaged t-case but I had ADD front setup (no manual hubs) -from factory. Obviously you can make it work..... but.... There are electrical & vacuum (?) related items in there that make it more complicated. Once the t-case is in 4WD, something has to 'sense' its in 4WD and send signals to something else ???? that'll engage the front diff. From what I understand, it's vacuum related which the vacuum comes from the engine itself.
    So, if all this is new to you....you're probably better off finding a non-ADD front diff (and axle shaft setup) with manual hubs (all as a unit) - and avoid all that vacuum & electrical stuff completely.
    Unless of course, you enjoy researching and the challenge of doing it? Go 4 It.
