PreRunner B.S.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Mar 7, 2011.
  1. Aug 2, 2016 at 3:02 PM
    #4341
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Lived in Columbus until I was 8. My dad still lives in the area.
    tylerb2011 and ChadsPride like this.
  2. Aug 2, 2016 at 3:22 PM
    #4342
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Gone rain here all week! ...
    Still not a prerunner :hattip:
  3. Aug 2, 2016 at 4:19 PM
    #4343
    J Red
    J Red Well-Known Nobody
    Georgia..... USA
    2009 SWDCSB PreRunner SR5
    I had thought about that, too. I need to not over think it and start simple and eliminate what possiblities I can myself. Start with regular maintenance stuff and go from there.
    I do appreciate your input. Thanks!
  4. Aug 2, 2016 at 5:57 PM
    #4344
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    You're welcome, wheel bearings are easy to check while you're checking the regular maintenance stuff.
  5. Aug 3, 2016 at 3:39 AM
    #4345
    J Red
    Georgia..... USA
    Yeah. I'm not a mechanic, but I can do the average parts changing and maintenance.
    :bananadead:
    I did mess up a brake job on my Ranger... Forgot to grease the sliders. The pads bound up and wore out premature. Not my proudest moment when I saw what was happening! :annoyed:
  6. Aug 3, 2016 at 4:41 AM
    #4346
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    That's how you learn. Haha
    To check your wheel bearings Jack up your truck, grab the wheel at the top and bottom and try to rock it. There shouldn't be much movement.
    Visual help. :D
    https://youtu.be/OqFSRXA_RQA
  7. Aug 3, 2016 at 11:44 AM
    #4347
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Definetly check the bearings, i have 201k on my truck and ive changed out three of them so far. Mine always made the most noise while driving 45-55mph
    Also, if it is a front one mine would stop making noise when turning one direction. When the front left was bad, it would stop making noise when turning right
  8. Aug 3, 2016 at 11:48 AM
    #4348
    Iamraiderpower
    Iamraiderpower Well-Known Member
    im on my 3rd set in my 2015 right at 20k miles now. No one has any clue why either...Just got it back yesterday after replacing the newest set.
  9. Aug 3, 2016 at 11:49 AM
    #4349
    BassAckwards
    Damn.. Thats pretty bad.. Mine all lasted over 100k before i had to start replacing
  10. Aug 3, 2016 at 1:38 PM
    #4350
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Did it cause a shake in the wheel at the same mph range? I just had my tires balanced & still have a shake but not as bad as it was.
  11. Aug 3, 2016 at 1:43 PM
    #4351
    BassAckwards
    No sir, no shake in the wheel at any speed. Just a noticable groan when going around 45-55
  12. Aug 3, 2016 at 2:12 PM
    #4352
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    For future reference did you replace with OEM or did ya use after market bearings? Which ones are best to replace with or are they all about the same?
    tylerb2011, J Red and ChadsPride like this.
  13. Aug 3, 2016 at 2:18 PM
    #4353
    BassAckwards
    I used OEM on mine so i cant comment on the quality of aftermarket, but i cant imagine them being much worse than the toyota ones.
  14. Aug 3, 2016 at 2:30 PM
    #4354
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Ok thanks, so it must be one of my tires then.
  15. Aug 3, 2016 at 2:34 PM
    #4355
    J Red
    Georgia..... USA
    Good info. I haven't noticed any difference when turning. I don't normally try to take turns at 45-55 mph, either.... J/k. I get what you mean about turning. I had an '80 280zx that I experienced that in, tho. This seems different. I'm thinking it's either tires or the carrier bearing.
    I checked the muffler bearing, blinker fluid, and rotated the windshield wipers.... None of that fixed it. :rolleyes:
  16. Aug 3, 2016 at 2:38 PM
    #4356
    J Red
    Georgia..... USA
    Wow.... 3rd set in 20k? Front or rear? Could it be a slight bend or imperfection in the axel....? Just a guess. Usually it misalignment or overloading that wears bearings out. Besides the obvious.... Mud, sand, shavings, etc...
  17. Aug 3, 2016 at 2:39 PM
    #4357
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Have you guys thought about trying this?
    https://www.tacomaworld.com/threads...-complete-save-custom-built-available.288055/
  18. Aug 3, 2016 at 2:45 PM
    #4358
    ChadsPride
    Sponsored by TacomaWorld.com
    tylerb2011 and J Red like this.
  19. Aug 3, 2016 at 2:50 PM
    #4359
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah he says it cause the aftermarket company he gets the 4x4 flanges from doesn't have 4x2 flanges so he has to use toyota flanges.
  20. Aug 3, 2016 at 2:50 PM
    #4360
    Iamraiderpower
    Its because of the need for the Toyota flange and hub nut
