Prerunner diff question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drewski, Oct 8, 2011.
  1. Oct 8, 2011 at 8:25 PM
    Drewski
    Drewski [OP] Well-Known Member
    People's Republic of Chicago
    '99 Prerunner SR5 Xtracab 4 cyl auto
    So I've been a Gen 1 owner for about 6 hours now :D and I've been going over the truck with the proverbial fine toothed comb. One thing I could use some help with is the differential. I've read lots of posts here, but I still can't quite figure out what is going on in the rear axle.
    It's a '99 Prerunner TRD 2.7 auto. So, what kind of diff do I have in there? Seems like it's an open 4.10, but I don't know. Any help is appreciated!
  2. Oct 8, 2011 at 8:39 PM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Use this link and your rear end code for some good info.
    rear end
  3. Oct 8, 2011 at 8:59 PM
    Drewski
    Excellent. Thanks.
  4. Oct 8, 2011 at 9:03 PM
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    i didnt know they had 4cyl TRDs
  5. Oct 9, 2011 at 4:07 PM
    Drewski
    The author of that page seems to have some question, but it seems my set up is an 8" 4.30 2 pinion open diff. There is apparently no e-locker switch in the cab, but where I think it is supposed to be, there is a mysterious red light that is on all the time. I was looking around under the truck today (so cool to have a vehicle again that I don't have to lift to get underneath) and noticed something on the right side of the pumpkin. At first I thought it was for the e-locker but...?
  6. Oct 9, 2011 at 4:17 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    I don't think 1st gen TRD Prerunners got factory E-Lockers... But yeh A PreRunner with a 4cyl and an auto is usually a 4.30 rear end.
    If your still not sure you could always just go get it stuck and see how many tires spin when you goose it... :D
  7. Oct 9, 2011 at 6:51 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    They don't
    Mysterious red light most likely would be an alarm or reminance of one (if I had to guess).
    You took the picture of the wrong side of the axle if you're asking for help on whether you have an elocker or not. E locker actuator is actually a part of the third member, adjacent the driveshaft.
    The object pictured to the right is the brake proportioning valve. Depending on the load in the bed it adjust the brake bias.
    All TRD's, whether prerunner or 4x4, have the E-locker.
  8. Oct 9, 2011 at 7:01 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  9. Oct 9, 2011 at 7:14 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    Oh. I wasn't sure, but I guess they do! Shows how much I know. :p
  10. Oct 9, 2011 at 7:44 PM
    Drewski
    They do
    Not this one.
  11. Oct 9, 2011 at 8:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I stand corrected. The e locker comes on all V6 TRDs (prerunner and 4x4 alike).
    The TRD 4 banger is apparently somewhat of a rarity and no locker.
    1st gen TRD's (at least the v6) also gets a gas tank skid plate. Do you have a gas tank skid or did you get fucked out of that too?
  12. Oct 9, 2011 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The TRD package was an option for the trucks with the 2.7L (prerunner or 4x4), however, if it had an auto tranny, no e-locker. The trucks with 2.7L and 5-speed and TRD package have the factory e-locker.
    Edit: Further reading for those interested.
    http://www.tacomaworld.com/forum/1s...stion-how-can-i-identify-if-my-truck-trd.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/168500-how-tell-trd-truck.html
  13. Oct 10, 2011 at 1:39 AM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    I have a 99 3.4 no e locker prerunner with code b03a which it says is a 4.10 open 2 pinon and my truck came with 225/75r15 tires
