Prerunner locker operation?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hagar71, Jan 14, 2007.
  1. Jan 14, 2007 at 2:58 PM
    hagar71
    hagar71 [OP] Member
    ok whats the idea behind the locker and is it usefull? it says to only use to get ya out when stuck and the turn it off? cant you ride with it locked? i mean almost seems pointless?
  2. Jan 21, 2007 at 2:35 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    the locker makes both of the back tires spin the same amount the are locked together you are not supose to drive with it on or on hard roads because when you take a corner the inside tire wont slow down so it drages around the corner and when you have the locker on it puts alot of stress on everything to engage the locker you have to be in 4low
  3. Jan 22, 2007 at 3:42 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Well, yes, except he is looking at the PreRunner.
    Like 2003greenbean said, the wheels will turn at the same rate with the locker engaged. Because of this, it will eat tires quickly and cause excessive wear and tear on your entire rearend.
    A locker is great to get out of a tough spot, but it is not as good as 4 wheel drive. I am going to install an aftermarket Limited Slip Rear on my 2007 PreRunner. For more information about that, check this out... Limited Slip Rear
    It talks about limited slip rear (like posi-traction) and a few jabs at lockers.
