Prerunner locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by mat, Nov 25, 2010.
  1. Nov 25, 2010 at 11:32 AM
    mat
    mat [OP] Well-Known Member
    01 prerunner sr5
    elite offroad front bumper, tool box, rustoleum bed liner, fog lights, alpine head unit, homemade bed extender
    Anyone put an aussie locker on an '01 prerunner?
  2. Nov 25, 2010 at 11:33 AM
    mat
    01 prerunner sr5
    I really need help on this one. I know it can be done but i dont know if the '95-'99 standard 4X2 locker will fit on mine.
  3. Nov 25, 2010 at 12:40 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im pretty sure you can, you just have to get the correct locker for your application. you will probably have to get your gear ratio and ring gear size before you order it..
  4. Nov 25, 2010 at 12:53 PM
    mat
    01 prerunner sr5
    Ive been trying to find the correct one but they dont have one listed on the aussie website and im not sure if the prerunner has the same gear ratio as the standard 4X2 or if the gear ratio changed between 99 and 2001
  5. Nov 25, 2010 at 3:49 PM
    98_Mud_bug
    lucedale Ms.
    here is a thread on how to figure out what your gear ratio is. your best bet would be to call them and find out..
  6. Nov 25, 2010 at 3:56 PM
    mat
    01 prerunner sr5
    Call toyota?
  7. Nov 25, 2010 at 4:04 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Should be the standard 8.4 rearend. Gear ratio shouldn't be a factor.
  8. Nov 25, 2010 at 4:08 PM
    Matic
    Rich
    Greenville,sc
    Yea. I see on thre webpage that it is only 95-99. I would just call Aussie. Or maybe look into a poertrax no slip or lock rite.
  9. Nov 25, 2010 at 8:31 PM
    mat
    01 prerunner sr5
    yea i thought it was an 8.4 but it seems to be different for every different model such as v6, prerunner vs non prerunner, 4wd so i havent been able to find out the exact size of the ring gear. Hey matic, what kind of bumper is that?
  10. Nov 25, 2010 at 8:49 PM
    Matic
    Rich
    Greenville,sc
    I think the 8.4 is actually refered to as an "8" if i'm not mistaken. I went thru the exact same thing with my "02" prerunner and buying my powertrax no slip. If you go to the powertrax website they list the same as the aussie site. They dont even show my year.
    (download the pdf) They just show 95-99 as well but when I called and talked to the guy her said it was "8" even though toyota refers to it as a 8.4. And he hooked me up with a powertrax no slip which I absolutely love.
    Call Aussie or powertrax and ask them strait up. The one good thing about toyotas for our year and earlier is they really havnt changed much as far as rearends. I think there 7.5's and 8.4 (which I think is just a 8" rg.) Also your prerunner is basically a 4x4 without the transfer case. Uses the same rearend/frame/brakes/struts/shocks.
    Call and ask. I bet he tells you it's the same.
  11. Nov 25, 2010 at 8:49 PM
    Matic
    Rich
    Greenville,sc
    It's an All Pro. :)
  12. Nov 25, 2010 at 8:52 PM
    Matic
    Rich
    Greenville,sc
  13. Nov 26, 2010 at 7:54 AM
    mat
    01 prerunner sr5
    so according to this every '95-'99 model has an 8 inch with 30 spline? And it didnt change between then and 2001?
  14. Nov 26, 2010 at 7:59 AM
    mat
    01 prerunner sr5
    Ok thanks alot ill call aussie today
  15. Dec 10, 2010 at 7:52 AM
    mat
    01 prerunner sr5
    so i called them and emailed them a few weeks ago and they never got back to me. most say that aussie has good customer service but it so far has not been my experience. so i guess i will order the 8 inch 30 spline and if it doesnt fit send it back
