Prerunner on sand tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hbryanlopez, Oct 14, 2010.
  1. Oct 14, 2010 at 2:49 PM
    hbryanlopez
    hbryanlopez [OP] Well-Known Member
    herby
    mcallen, tx
    black out headlights bilstein 5100s toytec 2" aal procomp 7089 nitto terra grapler 285/70/17
    I have a prerunner and will be taking it to the beach. Here where I live there is a hot spot for fishing. But to get there you have to drive 35miles on the sand by the water. I will be going with a jeep rubicon incase I get stuck but what should I do to avoid getting stuck. I currently have bilstein 5100 all around, front at 2.5" and 2" rear aal. 285/70/18 nitto Tera graplers. Any tips? I won't be going on really soft sand but I do plan to do this 2-3 Times a year. Would a rear dif locker help? This will be the only offroading I will be doing. Any tips would be great.
  2. Oct 14, 2010 at 2:53 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    air down and dont do shot gun start
  3. Oct 14, 2010 at 2:55 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    youre going to get stuck no matter what!
  4. Oct 14, 2010 at 2:56 PM
    08pretaco
    Oliver
    az
    and by air down like 15psi and yes u might get stuck still
    are you open diff, lsd, trd locker?
  5. Oct 14, 2010 at 3:00 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    SacTown
    Trd offroad prerunner
    285/65/18 nitto trail grapplers w/ xd revolvers, second air filter removed, k&n drop in, maxtrack spindle, pro comp aal, 20% tint all around, ebay halos,rigid industries led lights behind my satoshi kenwood shallow mount subwoofer in custom box, kenwood stereo, black lower valence, plus my custom cracked windshield
    havent taken the tacoma out on the sand yet, but have taken many other trucks out in soft sand....air down and dont take off fast like earlier stated. the terra grapplers do great in sand, and your gonna be next to the water so itll be hard packed wich is easy to get through, take a shovel and maybe a couple pieces of wood so if you get stuck u can put them in front of the tire to help it get traction. dont forget a tow strap haha ive done that one a few to many times
  6. Oct 14, 2010 at 3:03 PM
    jonny
    jonny Betty White Edition Heep ZJ
    air down and easy on the gas. my NTG's did great aired down in the sand :thumbsup:
    or a little more costly solution: do what i did... trade in for a 4x :p
    jk
    kinda
    enjoy the sweet fishing spot!
  7. Oct 14, 2010 at 3:04 PM
    08pretaco
    Oliver
    az
  8. Oct 14, 2010 at 3:11 PM
    yamaha73
    Royce
    SacTown
  9. Oct 14, 2010 at 3:15 PM
    08pretaco
    Oliver
    az
    exactly that would work, posted the pic for visual reference! i wouldnt spend money on that if i could make it
  10. Oct 14, 2010 at 3:20 PM
    yamaha73
    Royce
    SacTown
    yea im gonna do it soon since im going to pismo in a couple weeks, the picture u showed is that like rubber, almost like tread from a tire?
  11. Oct 14, 2010 at 3:21 PM
    hbryanlopez
    herby
    mcallen, tx
    Thanks guys..I have lsd do I leave that on? Also is it ok o drive 35 miles on 15 psi? Ive been a couple of times with my buddy with a rubicon, his avg speed is 35mph is this ok speed at only 15psi! And should I do all 4 tires at 15psi.
  12. Oct 14, 2010 at 3:21 PM
    08pretaco
    Oliver
    az
    i believe so. i just did a google picture search but if you go to arb's website it will give you more detailed info on it!
  13. Oct 14, 2010 at 3:23 PM
    08pretaco
    Oliver
    az
    its fine to drive like that with such low psi as long as its not asphalt. yes you should do all 4 at 15psi. the lower tire pressure creates less "drag" you could say by spreading the surface area of the tire over a larger area. so if you did not deflate the front they would be kind of pushing the sand instead of a more floating action!
  14. Oct 14, 2010 at 3:25 PM
    yamaha73
    Royce
    SacTown
    ive had buddys with long travel trucks theyve done 60 with there tires aired down for 3 days with no problems so id say ur fine
    edit: o and just dont be doing donuts with your tires aired down, buddy of mine was a retard and was doin donutes with his tires at 12psi, broke the bead on the tire, not fun to take the tire off in sand and get the bead to go back on
  15. Oct 14, 2010 at 3:26 PM
    yamaha73
    Royce
    SacTown
    ok thanks!!!
  16. Oct 14, 2010 at 3:28 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    go to 10psi momentum is the key!
  17. Oct 14, 2010 at 3:30 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Only air down your drive wheels. Airing down the fronts of a 2wd will do no good
  18. Oct 14, 2010 at 3:32 PM
    kinkrider101
    santa barbara
    wheels and tires
    it helps steer tho and doesnt dig when you steer
  19. Oct 14, 2010 at 3:43 PM
    yamaha73
    Royce
    SacTown
    yes airing down the fronts helps, the tires are wider and float over the sand better instead of pushing the sand like it will do with it all aired up
  20. Oct 14, 2010 at 3:51 PM
    08pretaco
    Oliver
    az
    Iv always aired all 4 as well as been taught. Theres an ongoing thread on here about it and will help you make your own educated dicision on what to do
