PreRunner to 4x4 Conversion Guide
Discussion in '4 Cylinder' started by 05Taco4x4, Feb 16, 2018.
  1. Jun 12, 2018 at 11:44 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I'm lost. Which wires go where? F12 11, 19, C10 15, 16?? Did you make a harness from the F12 to the transfer case switches?
    Sae68 likes this.
  2. Jun 12, 2018 at 1:17 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    F12 pin 19 (red wire) goes to C10 pin15 (red wire), the same is true of the brown/white wire; this means you can make a harness from the sensors to C10 or F12. The red wire is for the 4WD sensor, the brown/white for 4Lo.
    Sae68 likes this.
  3. Jun 12, 2018 at 2:16 PM
    Y2kbaja
    Sacramento
    Total Chaos
    So all I have to do is ground 1 side of the 4wd switch on the TC and the other side of the TC switch run to F12 #19 and the light will go on with 4wd? Seems too easy.
  4. Jun 12, 2018 at 2:24 PM
    05Taco4x4
    2TR-FE Enthusiast
    Ground one and other to F12 pin 19, just that easy :thumbsup:
  5. Jun 12, 2018 at 2:28 PM
    Y2kbaja
    Sacramento
    Total Chaos
    Thanks. Seriously, Thanks. I have been avoiding this--not wanting to break into the instru cluster.
    05Taco4x4[OP] likes this.
  6. Jun 12, 2018 at 2:30 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Excellent work
    hoverlover and 05Taco4x4[OP] like this.
  7. Dec 25, 2018 at 9:45 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I need this in my life...
    Might be moving to Kentucky so I'm gonna actually need this :laugh:
  8. Jan 23, 2019 at 2:32 PM
    Boombaasta
    Boombaasta New Member
    Aaron
    2020 Red Toyota Tacoma SR5 4X4
    Looking into doing this for my 2010 Tacoma Prerunner Double cab AT. Are there any issues with routing the exhaust or can I use my stock exhaust? Also, where can you buy the ADD module and front crossmember? I don't have a welder or any experience welding... So I want to avoid doing anything like that.
    asudevil and hoverlover like this.
  9. Jan 24, 2019 at 7:02 AM
    Y2kbaja
    Sacramento
    Total Chaos
    There is cutting, welding and a great deal of mechanical and fabrication to do a conversion. It's not for the faint at heart. IF my truck was stock I would have sold it and bought a 4x4. But I'm no where near stock, so for me, it was worth it. My buddy was the same way. Priced out a caged 2wd built prerunner and convert to 4wd vs a built 4x4 and add a cage. He bought 2wd and sent the truck to RST and had them do the conversion. He also had all the 4wd stuff from his wrecked FJ.
    So with no welding or fab experience I would advise selling the prerunner and buy a 4x4.
  10. Feb 1, 2019 at 3:44 AM
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    '24 Subaru Crosstrek Premium
    Sooooo...
    When do you want to come over and help me with this? :rofl:
  11. Feb 15, 2019 at 9:57 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Great write-up, love the IPB's too.
  12. Jul 10, 2019 at 6:42 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    so our trucks come prewired for this?
  13. Jul 10, 2019 at 10:14 AM
    05Taco4x4
    2TR-FE Enthusiast
    You’ll have to look
  14. Jul 10, 2019 at 10:17 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    was yours
  15. Jul 10, 2019 at 10:19 AM
    #35
    05Taco4x4
    2TR-FE Enthusiast
    I swapped my interior harness from a higher optioned truck to add keyless and other options at the door so couldn’t tell you how it came originally. Should only take 5 minutes to find those wires either behind/above the glove box or instrument cluster
    Brian422[QUOTED] likes this.
  16. Aug 16, 2019 at 4:53 PM
    #36
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    nice write up lots of good info :thumbsup:
  17. Dec 15, 2019 at 8:34 PM
    #37
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    How did you make your harness for the indicator lights? What gauge wiring? So you just ran your harness from the TC wires to the corresponding wires on pin f12 in glove box which corresponded with the c10 pins on the insta cluster? Grounded the other wires?
  18. Jan 6, 2020 at 12:03 PM
    #38
    campfiretaco
    campfiretaco Well-Known Member
    Middle TN
    2011 PreRunner DCSB
    If I bought a 4x4 rear driveshaft would it bolt right on or would it still require some modification/shortening to fit the new tcase?
  19. Jan 6, 2020 at 12:10 PM
    #39
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    campfiretaco[QUOTED] likes this.
  20. Mar 25, 2020 at 4:18 PM
    #40
    Tennessee98
    Tennessee98 Well-Known Member
    2007 Tacoma supercharged
    That f12 wiring harness where exactly would it be located behind the glove box. Thanks
