prerunner to 4x4 conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Apr 20, 2011.
  1. Oct 4, 2015 at 7:01 AM
    #61
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Sub'd doing a conversion and an 3.4l engine swap too.
  2. Oct 4, 2015 at 8:34 AM
    #62
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Best thing you'll do
  3. Oct 4, 2015 at 8:40 AM
    #63
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  4. Oct 4, 2015 at 8:42 AM
    #64
    bellassaiw10
    Currituck NC
    I came across a few when I was doing my swap I'll get the links when I get off work
    SilverGhost likes this.
  5. Oct 5, 2015 at 8:19 AM
    #65
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    You might want to consider a 5speed tranny swap too since you are down for the do
  6. Oct 5, 2015 at 9:14 AM
    #66
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Every one here in Co wants me to add a stick. But I'm not a stick kind of guy. I like my auto.
  7. Nov 14, 2015 at 11:57 PM
    #67
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    enlighten me
  8. Nov 15, 2015 at 12:07 AM
    #68
    neegdogdig
    3rd Gen DC V6
    image.jpg image.jpg image.jpgAxles swapped, tranny swapped, stereo swapped and tons mores... money ain't worth the truck. Prerunner to 4x4 5speed in a dc :thumbsup: 1 in millions:D
  9. Nov 15, 2015 at 6:50 AM
    #69
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    So in the image below it show that there is a ADD Relay for the non switch shifter. Where exactly is it at? Or I everything controlled by the ECU.
  10. Nov 15, 2015 at 10:13 AM
    #70
    neegdogdig
    3rd Gen DC V6
    In my case it's a different story my was stick I swapped the stock ecu with the new 4x4 ecu so there isn't any relay needed. When angage the 4wd there isn't any indicators on the dash since my is a Prerunner converted but still sweet too sweet to drive.
  11. Nov 15, 2015 at 11:33 AM
    #71
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah I also have an ECU that I'm going to swap in. I was hoping that's all I needed. Then I stumbled onto that relay pic. Now it's having me think if I need one or not. I'll keep looking around. Thanks for the reply.
  12. Jan 1, 2016 at 9:53 PM
    #72
    99Runner3.4
    99Runner3.4 Well-Known Member
    Lucas
    2009 4x4 TRD Off Road DCSB
    Do you have to swap the factory Ecu? I have a 1999 prerunner with a 3.4l automatic transmission. I've read that the auto tranny is a a340e while the manual is a r150f. Can I swap a manual tranny in with a 3.4l v6 that was factory automatic?
  13. Jan 2, 2016 at 11:27 AM
    #73
    neegdogdig
    3rd Gen DC V6
    To kill the cell light your tranny has to go along with your ecu both auto or both manual
  14. Jan 2, 2016 at 1:59 PM
    #74
    99Runner3.4
    Lucas
    So if I have an auto tranny and I switch to a 4x4 auto tranny I don't need to switch ecu?
  15. Jan 3, 2016 at 10:34 AM
    #75
    neegdogdig
    3rd Gen DC V6
    You need a 4x4 ecu to match up with your tranny
  16. Jan 3, 2016 at 11:31 PM
    #76
    mahaloTaco
    Max
    Los Angeles
    What did you end up doing?
    How did the search go?
    Did you end up making the conversion?
    :bananadance:
    Congratulations:thumbsup:
    Did you end up making the swap?
  17. Jan 6, 2016 at 6:45 PM
    #77
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    I never changed my ECU when I converted to 4x4. I slapped in a 99 4Runner Auto with Electric actuated TC into my 02 PreRunner. The only think that I had to swap from the 2wd transmission was the park/neutral safety switch as the connectors were different. It shifts at different points than the 2wd, but I think it's due to the 4Runner part. Been working great for 5 years now. As for the TC, I just wired in a Dual pole dual throw switch with a relay and indicator lights. Works and tells me if the TC is in 2 or 4.
    Area51Runner likes this.
  18. Jan 21, 2016 at 8:44 AM
    #78
    scrappytaco2002
    scrappytaco2002 New Member
    Brandon
    Statesboro , GA
    2002 DC Tacoma
    Im also putting together parts for 4x4 swap. I have an -02 3.4 auto, i have everything but a trans (maunal hubs / non add front diff) and i have access to a -01 4runner trans. There seems to be a difference in the plugs. Was there any in your swap that were left unconnected or had to splice / lengthen?
  19. Jan 21, 2016 at 3:03 PM
    #79
    hossmaster
    League City, Tx
    When I did my conversion i put a 99 4Runner trans into my 02 Tacoma. They only connector I had to change was the Park/Neutral safety switch on the trans as the connectors were different. I had to cut and extend the speed sensor connector to be able to reach to the back of the transfer case, maybe 1.5 feet???
  20. Jan 21, 2016 at 3:14 PM
    #80
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Not correct, the prerunner ecu is the same. My truck even has the 4wd control computer in the kick panel
