prerunner to 4x4 conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Apr 20, 2011.
  1. Sep 10, 2017 at 5:04 PM
    #101
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Whoops. Forgot about that difference on the 03-04s vs the older ones... And I cant remember exactly what it takes to swap between them...
    Def read up on it @wingedone and let me know.
  2. Sep 10, 2017 at 7:10 PM
    #102
    wingedone
    wingedone Well-Known Member
    2001 Toyota Tacoma
    Ok so let's say I decide to go with the manual trans it's the w59 98-2002? Thanks I'll do some more research. The mt would probably get me a few more miles out of a full tank. As it stands now, I'm getting a little under 300 miles out of a full tank.
  3. Sep 11, 2017 at 10:50 AM
    #103
    digitalferg
    Southern Utah
    There's a crap ton more work to do on going 5-speed manual during a prerunner-to-4wd conversion vs just going with the auto....with the auto you pretty much just pull out the 2wd auto and throw in the 4wd auto....(and the bolt on all the front axle stuff). With the 5-speed there is a big handful extra parts you gotta collect for the clutch...plus you gotta drill some new holes in the firewall for the clutch master. Anyway, ain't nothing somebody around here hasn't already done before, so plenty of threads and info out there on it... just know that its a lot more involved. :)
  4. Sep 11, 2017 at 6:15 PM
    #104
    wingedone
    2001 Toyota Tacoma
    Having a hard time finding a decent A340F with transfer case. I was unable to post in the f/s section. Anyone have any leads? Thanks
  5. Sep 11, 2017 at 9:18 PM
    #105
    digitalferg
    Southern Utah
    You know... Technically you can use your same auto trans and just convert it... You can go two different ways about it: OEM stuff or something like the "lefty" case from inchworm (low-range off road now).
    To go OEM route you need to get the output shaft from one of the 4wd trannies (the a340f), the proper tail-housing from the same, and a proper t-case. Should all be from a V6 if yours is V6. Some say the tcases are the same between v6 and 4cyl, but I dont know for sure there... The output shafts are for sure different though. So anyway, you just swap the shaft into your current trans, and bolt up the 4wd tail housing and t-case. Done.
    If you go with something like the "lefty" I think there is one that just bolts right up to the prerunner auto trans output. (I *think* this option might require resizing of both the rear *and* front shaft lengths....)
  6. Sep 12, 2017 at 8:29 PM
    #106
    HenryG
    HenryG Well-Known Member
    Washington State
    As of just a few days ago the inchworm option is no more. I contacted them about placing an order and was told they were sold out with no definite plans to produce the adapters in the future. Sucks because I was planning on going this route to use my current auto transmission. Maybe I'll look into converting the shaft to a 4wd version.
    digitalferg[QUOTED] likes this.
  7. Sep 13, 2017 at 1:40 PM
    #107
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Got a question for you guys that have done it. Being on a high school budget, money is something I've never seen before. So, to start the conversion process off, I want to do transmission first. My question is: Can I take a manual 4x4 Transmission and put it in the truck without the rest of the 4x4 components? Meaning can I block off the hole in the transfer case for the front driveshaft?
  8. Sep 13, 2017 at 3:31 PM
    #108
    wingedone
    2001 Toyota Tacoma
    Yup I called them yesterday am and same thing. Just gotta keep looking. Yards around here don't seem to have the 4x4's.
  9. Sep 13, 2017 at 4:18 PM
    #109
    digitalferg
    Southern Utah
    Yep. Sort of. You would have to do the transfer case at the same time as the transmission though. And there wouldn't be any hole or anything to block off, you would just not hook anything up to the front output flange on the transfer case.
    When I did the prerunner to 4wd conversion on my old Tacoma I did the trans and case at a completely different time than the front axle.
    jgill21[QUOTED] likes this.
  10. Sep 13, 2017 at 4:23 PM
    #110
    digitalferg
    Southern Utah
    Bummer about the Inchworm stuff. Seems like the 1st Gen Tacoma isn't getting as much love these days at it used to. Makes sense a bit though...lotsa folks moved on to 2nd and 3rd gens now.
    When I did mine, I swapped in a complete 4wd trans with case, but if I did it again, I would look into just swapping the shaft. (Or having someone do it)
    BTW, @wingedone , are you also looking at 3rd Gen 4Runner transmissions? They're the same thing. I used a 4wd 4Runner one when I did the swap....
  11. Sep 13, 2017 at 4:33 PM
    #111
    jgill21
    Jake
    Nashville
    We're talking about the transfer case on the end of the 4x4 transmission right?
    OH! I see now, the hub for the driveshaft is already on the transfer case
  12. Sep 13, 2017 at 4:51 PM
    #112
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yes.
  13. Sep 13, 2017 at 4:53 PM
    #113
    jgill21
    Jake
    Nashville
    So, say I have the correct 5 speed transmission and Transfer Case. All I need now is:
    Shorter 4x4 Rear Driveshaft
    Pedal Assembly
    Clutch Linkage
    Clutch Fluid Resevoir
    Interior Trim Pieces
    Correct?
  14. Sep 13, 2017 at 5:09 PM
    #114
    TashcomerTexas
    Pretty much. You're just looking to get that knocked out right?
    I'm not entirely positive if the 2.7 assembly and 3.4 are the same or not, be sure they are though.
  15. Sep 13, 2017 at 9:20 PM
    #115
    HenryG
    Washington State
    You're going from Prerunner to 4wd?
  16. Sep 13, 2017 at 9:31 PM
    #116
    digitalferg
    Southern Utah
    Well, there's a good handful more items to consider, but they could be "included" in your other items....
    -trans shifter
    -t-case shifter
    -shifter knobs for each
    -master cylinder
    -slave cylinder
    -all the clutch fluid lines
    -clutch fork
    -correct manual flywheel (with good surface)
    -clutch kit (clutch disc, pressure plate, pilot bearing, throw out bearing, and alignment tool if you dont have one)
    -correct trans crossmember mount
    -bell housing
  17. Sep 14, 2017 at 5:05 AM
    #117
    jgill21
    Jake
    Nashville
    Eventually, but I just want to do transmission for now
  18. Sep 14, 2017 at 5:06 AM
    #118
    jgill21
    Jake
    Nashville
    Im pretty sure they're different
  19. Sep 14, 2017 at 7:12 AM
    #119
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Took me months to convert mine to 4WD. Had to plan each weekends progress with an eye on driving the truck to work the following week.
  20. Sep 14, 2017 at 7:16 AM
    #120
    jgill21
    Jake
    Nashville
    How did you go about getting a transmission?
