Prerunner with XSP 20" 265/50R20 tires upgrade to 35's for 6 inch lift.
Discussion in 'Wheels & Tires' started by Chayes119, Jan 19, 2012.
  1. Jan 19, 2012 at 7:15 AM
    Chayes119
    Chayes119 [OP] Long Member
    Georgia
    06 PreRunner SR5 BLK
    I have a 06 Prerunner with the XSP package with the 20" wheels and 265/50R20 tires. I am putting a 6" lift and need to know what size tire will fit my rim for a 35" inch tire.
  2. Jan 19, 2012 at 7:15 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    what is the rim width?
  3. Jan 19, 2012 at 7:36 AM
    Chayes119
    Georgia
    My research tells me that they are 8.5 wide. They are the Enkei WT4 rims.
  4. Jan 19, 2012 at 9:08 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Probably just a 35x12.5x20 is what you should be looking for. That would be a 315/60/20 in metric.
    Check to see how much other folks have had to trim to run 35x12.5s.
    The backspacing/offset of your rims will be a major factor as well
