Pressure washer issue.
Discussion in 'Detailing' started by Venom, Dec 22, 2019.
  1. Dec 22, 2019 at 3:43 AM
    Venom
    Venom [OP] Well-Known Member
    Kevin
    Massachusetts
    I'm not sure if this question is in the right area. The pressure washer is going to be used to wash vehicles among other things.
    My gas powered pressure washer would lose about 60% to 70% of it's pressure. Then return after a few minutes. There's no hissing or spitting as if there was any air in the system.
    Is this normal?
    It's my first pressure washer, so I don't have any experience with it.
  2. Jan 12, 2020 at 4:30 AM
    Venom
    Kevin
    Massachusetts
    Just a update, I called FNA Group. Their suggestion was to take it in for repairs under warranty.
    Since I'm having issue already, I ended up returning it to Home Depot under their 90 days return policy.
  3. Jan 15, 2020 at 2:46 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Venom[OP] likes this.
  4. Feb 11, 2020 at 9:56 AM
    jay993
    jay993 Well-Known Member
    Jay
    09 TRD Sport V6 AC
    bone stock
    you can never have too good of power washer!
  5. Feb 13, 2020 at 6:13 AM
    Venom
    Kevin
    Massachusetts
    The pressure washer that I bought and return was the Simpson model # 60735 at the Home Depot.
    I borrowed a 2450 PSI, 2.1 or 2.2 GPM Troy Bilt. The Simpson clean faster, and better. Remove stuff the other pressure washer couldn't.
    The only problem was I couldn't reach the highest part of the house. Neither pressure washer couldn't reach. Their wasn't much differences in the water steam distance. Consider their about 1000 PSI difference between the 2 pressure washer. I probably would buy another Simpson pressure washer, hopefully with better luck, on the next one.
    Does anyone knows if it normal to hold the spray gun handle while starting?
    Is it normal to put the choke on the half way mark when the motor is hot, to start it?
