Preventative measures for failure of secondary air pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hexnutter, Nov 10, 2021.
  1. Nov 17, 2021 at 7:42 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Youll never get that much water in the engine bay. But if youre worried about it you can buy the plastic cover piece from a member on here no longer using theirs. Believe it will fit over the uni-filter with minimal trimming.
    The only time Ive had issues is after hosing down the engine bay and forgetting to dry the uni-filter off before starting the truck.
    Edit: Not saying Ive had an actual issue yet because I havent. But did make myself cringe as soon as I started it up and heard the pump running. Knew whatever water was on the filter just got sucked in.
  2. Oct 12, 2022 at 11:42 AM
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    The Air Filter is definitely the step in preventing this issue. I wanted to provide a few other resources on the failure prone Secondary Air Injection System. The question is not "If" it will fail but "When" it will fail. If you have any questions do not hesitate to reach out, DM or give us a call.
    What Does the Secondary Air Injection System Do?
    https://www.tacomaworld.com/threads/what-does-the-secondary-air-injection-system-do.780847/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tacomaworld.com/threads/what-do-my-secondary-air-injection-error-codes-mean.780848/
    How to Fix Secondary Air Injection System?
    https://www.tacomaworld.com/threads/how-do-you-fix-the-secondary-air-injection-system.780849/
  3. May 12, 2024 at 12:48 PM
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
    Just thinking of cleaning the uni filter, but can’t remember if it came oiled?
  4. May 12, 2024 at 2:36 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    Did the conversion about 8 months ago, the filter did not come oiled.
    nightcrawler[QUOTED] likes this.
